Old July 19th, 2008, 09:52 AM   #1 (permalink)
studio1087's Avatar
Question about reverb pedal volume issue..
I have a Marshall Reflector and I like the sound.
I play clean 85% of the time - no reverb problems clean.
When I kick on my Bad Monkey or Boss SD-1, the amount of reverb in my tone triples.
It's annoying.
Do all reverb pedals react this was (reverb volume increase) with a distortion pedal or is the Reflector funky?
Thanks!
John
JLG
Carry On
Old July 19th, 2008, 10:32 AM   #2 (permalink)
andrenighthound's Avatar
i get the same problem with delay pedals.
i think the only solution for that is to have an ex loop built into the amp so your reverb pedal would be after the preamp.
"Blues in a doggy bag, is what I got to eat!"
www.andreandthenighthounds.com
andrenighthound is offline   Reply With Quote
Old July 19th, 2008, 10:35 AM   #3 (permalink)
play_loud's Avatar
Generally I found that reverb doesnt sound as great once you start dialing in heavily distorted/ overdriven sounds (ie/ it sounds muddy). This means that when I plan on using distortion in a song, I tweak the reverb on my amp down abit to compensate.
I cant answer your question directly, i've not played a Reflector... But if you're driving the amp with od/ dist wouldnt you expect an increase in reverb anyway, along with a general volume boost in the signal? Unless you have your pedals set up with equal volume levels across clean and dist. sounds. That would be weird I guess... I would assume it happens with most reverb pedals in that case, even if I havent witnessed this phenomenon first hand.
Cheers.
Chris.
play_loud is offline   Reply With Quote
