Old July 18th, 2008, 12:25 PM   #1 (permalink)
Reverse Effect
Looking for a box that will allow me some reverse delay to get that 1960s effect for backward leads. Any suggestions ?
Dokushin is offline   Reply With Quote
Old July 18th, 2008, 01:45 PM   #2 (permalink)
Moderator
getbent's Avatar
The DL4 does that I believe.
on the low end, the Danelectro reverse delay is pretty good... I have one and use it in the way you describe and it is fine for that.
'never pet a burning dog'
Old July 18th, 2008, 02:09 PM   #3 (permalink)
giginthesky's Avatar
i have 3 units that do that:
line 6 DL4
boss VF-1 (rack unit)
boss SE-50 (rack unit)
dokushin, these rack units can be bought used pretty cheap. (cheaper than a line 6) and, they are packed with other features and effects. welcome to the tdpri, btw!
j.
giginthesky is offline   Reply With Quote
Old July 18th, 2008, 02:10 PM   #4 (permalink)
guitarzan13's Avatar
The new Boss DD7 does it well. $159 and a great all around delay.....it also has a modulation and and analog setting!
Practice make permanent!!!!....Perfect practice makes perfect!!!
Chris B.
Current Band
www.productoffaith.net
Last band as a bass player
www.neonjones.com
guitarzan13 is offline   Reply With Quote
Old July 18th, 2008, 02:19 PM   #5 (permalink)
i believe the Boss SG-1 was the original pedal for a reverse guitar sound.
it's all just an approximation of that sound though (basically an envelope controlled volume swell)- I've tried the SG-1 and didn't particularly care for it- it's a trick best left for the studio. I do love that George Harrison Revolver sound though. maybe more modern units do it better, i don't know.
Reverse DELAY (reverb, echo), a la Phil Collins, is something that you can't even really come close to approximating in a live setting, just by nature of the beast (unless maybe you have a needlessly complex midi set-up with a previously recorded copy of pre-echos sync'ed up- actually, maybe not that complicated but then it's not really "live", either- off on a tangent here, sorry).
DJG105 is offline   Reply With Quote
Old July 18th, 2008, 03:00 PM   #6 (permalink)
vjf1968's Avatar
Take a look at these:
http://www.tdpri.com/forum/stomp-box...reo-delay.html
-Mark Mothersbaugh
Old July 18th, 2008, 03:05 PM   #7 (permalink)
SixStringSlinger's Avatar
You could also use a volume pedal. It'd be more involved than just clicking on a delay and playing the same as usual would, though.
"Is a hippopotamus a hippopotamus, or just a really cool opotamus?"
-Mitch Hedberg
SixStringSlinger is offline   Reply With Quote
Old July 18th, 2008, 03:56 PM   #8 (permalink)
The DigiTech DigiDelay has a reverse echo effect that's kind of uncontrollable, but cool-sounding in its own right. I use it at the end of "Strawberry Fields Forever" when playing live and it really fits. The DigiDelay also has a good tape echo function, and a great "ping-pong" stereo echo effect that works particularly well in my low-budget, '70s and '80s gear-based home recording studio, and with a guitar and two amps.
I got mine for $99.
Radspin is offline   Reply With Quote
Old July 18th, 2008, 07:34 PM   #9 (permalink)
octatonic's Avatar
I have the DL4 and various rack-mounted devices that do the job.
The DL4 is fine- but it does change the guitar sound if you are using it on the front end of an amp.
Best run in the FX loop.
Old July 18th, 2008, 08:02 PM   #10 (permalink)
ghosttour's Avatar
Line 6 Echo Park has a "reverse" setting. I found it a little difficult to use, but that's just me. Samples and info here: http://line6.com/tonecore/echoPark.html
www.myspace.com/brasssaddles
ghosttour is offline   Reply With Quote
