Old January 7th, 2004, 05:47 AM   #1 (permalink)
geddyleedog's Avatar
Question for ProCo Rat owners.
I've got a ProCo Rat, which a lot of people seem to love around here. I can't seem to get a great sound from mine. I have three questions that I might help me out:
1) What are your settings on the Rat from left to right?(for example - 12 oclock, 2 oclock, 9 oclock)
2) Do you use the Rat through a clean amp or to add some edge to an already overdriven amp?
3) Do you use the Rat for chording or just as an overdriven sound for your lead work?
Thanks again for any input you can give. I want to like this pedal!!!
(.o)==:::
geddyleedog is offline   Reply With Quote
Old January 7th, 2004, 11:45 AM   #2 (permalink)
A suggestion
Fellow TDPRIer Robbie Wallace does a wonderful mod (as I'm sure Robert Keeley, Analogman, and others do, too) that makes is smooth as silk. I'd shoot him a PM, then send him yours to enhance.
John Harrison is offline   Reply With Quote
Old January 8th, 2004, 07:31 AM   #3 (permalink)
I have a Vintage RAT, and I use (from L-R) 2 o'clock, 11 o'clock, and somewhere around 12 o'clock (I aim for no volume jump when I kick it in).
I use it with a clean amp, typically a Pro Jr, Velocette 10 or Princeton Reverb, and the amps are never driving. We only tend to play small places where even the Pro Jr or Velocette never really get to "lift off" levels. However, the RAT sounds best when there's another overdrive between it and the amp, that extra bit of comperssion and clipping seems to take away the harshness.
Cheers - SteveK
SteveK is offline   Reply With Quote
Old January 10th, 2004, 06:33 PM   #4 (permalink)
i use mine to drive my bassman a little harder, more of a boost as opposed to an overdrive. my settings are 9 o'clock, about 12 (it changes sometimes), and 3'oclock or more. i use more amp tube distortion as opposed to pedal distortion, so i always crank the outputs on my distortion pedals as opposed to use the overdrive on the pedal.
frakenstrat is offline   Reply With Quote
Old January 10th, 2004, 07:28 PM   #5 (permalink)
Lance's Avatar
Keely Mod
I really recommend it. The aggressive setting is amazing.
Lance
Old January 11th, 2004, 03:24 AM   #6 (permalink)
rat as colorizer
I agree with SteveK. I use my rat (vintage reissue) for adding just a touch of edge when playing slide thru my Hot Rod Deville 4x10. The stock overdrive channel in that amp is known for lacking character and the rat by itself (at least mine in my setup) is a little harsh, but the combination works well. It is a very narrow sweet spot range, but with the rat gain knob about 1/3 of the way up or less and the gain on the amp just barely overdriving the combination works.
-Paul
guitar_paul1 is offline   Reply With Quote
Old January 12th, 2004, 09:52 PM   #7 (permalink)
Matt Plescher's Avatar
Re: Keely Mod
robertkeeley.com
Robert has the old chips also, he switched mine out (I had a Rat with the newer chip) when he modded mine, and you can hear the difference with the old chip.
It is a distortion pedal, not an overdrive, and has a singular Rat sound. I don't use the original Rat setting at all, just Keeley mod settings.
I set the distortion at 900 and the others around 1100.
Cheers
Matt
She's not your satellite
She doesn't miss you
So turn off your smoke machine
And Marshall stack
Matt Plescher is offline   Reply With Quote
Old January 13th, 2004, 12:21 AM   #8 (permalink)
Cb
I set mine 9:00, 3:00, 2:45 for an amp-like overdrive with a slight increase in volume. I use BF & SF amps runing clean, with their volumes between 4 & 6.
A nice thing about those settings is that your tone will clean up nicely just by lightening your picking attack - the Rat will be very touch sensitive set like that.
Cb
Cb is offline   Reply With Quote
Old January 13th, 2004, 03:57 PM   #9 (permalink)
halouis's Avatar
fI use mine more for lead. so for a lead sound i do 10:00, 2:30, 2:30
for a rhythm, i'd increas the Dist a bit to perhaps 11-12:00 and decrease the vol accordingly. and might kick the filter to 3:00
i too have the keeley Mod and think its terrific. although a stock Rat smokes too. I usually use his "Phat" setting.
halouis is offline   Reply With Quote
