Old July 5th, 2008, 02:32 PM   #1 (permalink)
abstract's Avatar
dumb question about wah pedal battery drainage
Hey, I have a Vox wah which of course can only be powered by a battery. If I leave the cables plugged into it while its on my pedal board but there's no power running through the board, its just sitting in its case, will it still drain the battery???
Just wondering b/c I want to get my pedal board to where I just pull it out, plug in my guitar and amp and go. I'm sick of plugging and unplugging the wah every time.
Thanks in advance for answering my dumb question.
abstract is offline   Reply With Quote
Old July 5th, 2008, 03:19 PM   #2 (permalink)
SixStringSlinger's Avatar
It's not dumb. I'm not completely certain, but I'm 99% sure if you leave it plugged in it will drain the battery. This'll happen with about any battery-powered pedal, unless it also has an adaptor plugged in. For instance, the manuals for all my Boss pedals suggest having both a battery and an adaptor. The pedal uses the adaptor by default, so that assures constant power, and the battery is there to get you through a song or set if you accidentally unplug the adaptor from the pedal.
If you have the maual for your wah, it should say something about this. You can probably find it online if you don't have it.
"Is a hippopotamus a hippopotamus, or just a really cool opotamus?"
-Mitch Hedberg
SixStringSlinger is offline   Reply With Quote
Old July 5th, 2008, 05:59 PM   #3 (permalink)
Yoni's Avatar
there are adapters for when you don't have a power out. Like this one I'll be using when it shows up on tuesday.
http://www.musiciansfriend.com/produ...ble?sku=331506
Fall in Love it's Fun-EV
Check out my band at www.myspace.com/agent355
Yoni is offline   Reply With Quote
Old July 6th, 2008, 10:35 AM   #4 (permalink)
Big Lug's Avatar
Originally Posted by abstract View Post
... I'm sick of plugging and unplugging the wah every time...
No way around it unless...
If you place your wah first in your pedal line up--with no cable going into it--the battery won't be draining while it's sitiing in a case. I personally have my wah at the front end whenever I use it.
Just an idea.
“To be is to do” – Socrates
“To do is to be” – Jean-Paul Sartre
“Do be do be do” – Frank Sinatra
Big Lug is offline   Reply With Quote
vB code is On
Forums Directory
