Old July 1st, 2008, 06:14 PM   #1 (permalink)
Noise gate
My normal stomp box chain is Barber Tone Press, Blackstone Appliances, Maxon Delay, and BBE Sonic Stomp through a Champ with a Weber Minimass. I recently put a Bad Monkey after the Blackstone OD and like it a lot. I wouldn't use it a lot, since it is very wild. In particular, there is a lot of noise when I'm not playing, due to the high compressor settings that I'm experimenting with. I'm just having fun at home, so there's nothing major at stake here. Anyway, I'd like to cut off that noise due to the compressor because I pause a lot to write down what I am playing. I know I should play around with the settings, but right now I'm getting a good, fun sound. So I'm thinking about a noise gate. Any experiences with those?
Again, I know I can improve things by experimenting with the chain and settings, but I wonder how people find noise gates in these kinds of situations?
larry
Larry F is offline   Reply With Quote
Old July 1st, 2008, 06:23 PM   #2 (permalink)
kp8
kp8's Avatar
You can usually score a DOD FX30B for low dollars. They are awesome and have a bunch of useful features. A kind of swiss army knife pedal.
I don't use noise gates... but i do use the FX30 for signal gating an other things.
Otherwise a vol. pedal might work for that application.
-kp
Old July 3rd, 2008, 12:21 PM   #3 (permalink)
It's hard to beat the good old Boss NS-2. So simple: put your noisy stuff in the loop, and it's not noisy anymore. My live sound, because of the volume we play at, would have a constant wall of hiss without the NS-2.
bowman is offline   Reply With Quote
Old July 3rd, 2008, 07:58 PM   #4 (permalink)
klasaine's Avatar
I'm a fan of this one ...
http://www.isptechnologies.com/decimatorproducts.htm
It's really not too different than the Boss NS-2.
Tim Bowen shipped me his ns-2 to compare and they performed virtually identically with my gear.
I use mine at the beginning of my chain to quell my single coil p'up noise - the biggest offender - which in turn quiets ALL my OD's.
I chose the ISP frankly because I got a deal on one. It is built like a tank.
Old July 4th, 2008, 07:30 AM   #5 (permalink)
Jenix's Avatar
I disagree with the lot rootin for the ns-2. I found it sucked alot of tone and changed how my pedals sounded. Alot of people complain how it takes alot of the highs away.
When I was shopping for one it came down to Electroharmonix hum debugger or ISP decimator and I went with the decimator. The hum debugger only has two settings as to the isp has a knob. I pretty much just turn it until the noise goes away.
You need to find out what is causing the noise because some noise pedals perform better in other areas. The NS-2 is best with the fx loop send and return and the isp is better at the front of the chain. I think I've seen the ehx hum debugger at the end of the chain more.
My only complaint with the ISP decimator is when its turn on and I'm not playing its dead quiet but a little bit of the noise comes back when I strum a note. Not really that noticable but worth mentioning.
Good luck, check out the rocktron unit that just came out as well.
USA Ovation * (Big Baby Taylor - SOLD)
MIM Telecaster * Vox AC15CC
Takamine Classical G series
Martin 000C-16RGTE Aura
Some people sing in the shower, I play guitar...
Jenix is offline   Reply With Quote
Old July 4th, 2008, 08:51 AM   #6 (permalink)
fivenote's Avatar
That's pretty much the way the noise gates work. When you're not playing, the gate is closed and all noise is blocked. When you play, the gate opens to let your sound through, but also the noise. When playing with high-gain (the case when you most need the noise gate), the "bad" noise gets lost in amongst your "good" noise, and everybody's happy.
If you have significant noise in low-gain settings, then you have another issue with your gear. The noise gate won't help much since it lets that noise through when you play, and it's more noticable.
That said, I use the MXR SmartGate. Works fine. I don't notice any "tone suck" when its on.
fivenote
One day I'll finally have the perfect guitar for me. That's also the day I'll get arthritis. It was a fun ride.
fivenote is offline   Reply With Quote
Old July 4th, 2008, 12:34 PM   #7 (permalink)
bowlfreshener's Avatar
I like the NS-2, but I guess they aren't for everybody. But I figure if Yngwie uses one, then its good enough for me...LOL, Just kidding. My decision to use the NS-2 has nothing to Yngwie, but all because it does what I needed something to do. I do find that you have to take some time to find its "sweet spot" otherwise there may be some minor "squashing" issues. And technically the NS-2 isn't a noise gate, but a noise suppressor.
RAMA LAMA FA FA FA
bowlfreshener is offline   Reply With Quote
Old July 4th, 2008, 01:44 PM   #8 (permalink)
Interesting. Why not at the end of the chain?
Marc
msteurbaut is offline   Reply With Quote
Old July 4th, 2008, 02:19 PM   #9 (permalink)
Jenix's Avatar
if your noise starts with your pickups then every od or overdrive magnifies it. At the end of the chain theres alot more noise then at the beginning and alot more work for the gate to do which equals higher settings and more damage to your tone
Old July 4th, 2008, 02:24 PM   #10 (permalink)
klasaine's Avatar
My pedals are all quiet and I don't really play with a ton of gain. My only unacceptable noise issues are with my single coil axes in situations with 'dirty' power. Hence, at the top of my chain. I just want to reign in the buzz from my guitar. If a different situation arises with a noisy pedal I'd probably place it at the end(?).
Also as to the tone suck or tone change of the the NS-2. I auditioned both the Boss and the ISP and found that the Boss did "very slightly" attenuate the top end. But I actually liked what it did in my rig(?). The ISP does too - just differently. If and when I have to buy another gate I'd probably go for the Boss as it has more in and out options.
Old July 4th, 2008, 02:28 PM   #11 (permalink)
Thats how I use it at times as well...
RAMA LAMA FA FA FA
Old July 4th, 2008, 02:30 PM   #12 (permalink)
I've noticed this as well, but always just figured it was the top end just sounding like it should since some of the noise is being suppressed...
RAMA LAMA FA FA FA
Old July 4th, 2008, 02:46 PM   #13 (permalink)
klasaine's Avatar
Excellent point!
I feel that a little of the "sound" of single coils is their somewhat noisy top end. I hate all noisless singles and I really don't even really like that new Suhr (essentially a type of 'dummy coil') system for that very reason ... a little of the single coil "sound" IS the noise.
Old July 4th, 2008, 11:49 PM   #14 (permalink)
What I hear with an NS-2 engaged is a very slight bump in the mids. The ear could easily perceive this as attentuation in the highs, or maybe it's vice-versa. Either way, we're talking nitpicking of the borderline infinitesimal variety here, especially in a live setting. If the NS-2 is 'on all the time' (as I use it, other than as a master mute switch), then any needed EQ compensation is a quick and easy fix. I don't get on with noiseless singles either. Any time noise is suppressed, there's some degree of compromise involved. For whatever shortcomings the NS-2 has, I wouldn't go back to the 60 cycle hum fiascos that I endured prior to its employment, for all the tea in China.
"Everyone is different in how they learn, but for me, it's turning the pegs and just playing."
- BB
Old July 4th, 2008, 11:58 PM   #15 (permalink)
For my money, best Noise suppression unit has been the Rocktron Hush II. No discernible coloration of sound, and I even used it in my signal chain when mixing analog tape signals and MIDI info to PCM F1 and DAT stereo masters.
JohnSS is offline   Reply With Quote
Old July 5th, 2008, 04:22 PM   #16 (permalink)
tazzboy's Avatar
Sorry for hijacking your thread Larry F But I am curious to know if any one has try the Boss NF-1 Noise Suppressor? I have seen a couple of these on Music-Go-Round and was wondering what people thought of them?
tazzboy
Guitar: 1982 Gibson Les Paul Standard
AMP: 59 Bassman Reissue.
EFFECTS: 2 Boss TR-2 Tremolo, Boss CE-2 Chorus, and Boss DM-3 Echo Delay.
Old July 5th, 2008, 11:32 PM   #17 (permalink)
I've used one. More later.
I'm not qualified to say what the difference between the two is, but there's definitely a difference in my experience. The BOSS noise suppression circuitry (NS-2; discontinued NS-50 half space rack unit) claims to use a "high speed LFO envelope", maybe that's the difference, who knows.
Anyway, I auditioned a bunch of (at the time) studio-quality noise gate rack units in my live electric guitar rigs from about the mid 80's to the early 90's. The deal with a traditional gate is that if you set it to tame the noise for your higher gain settings, it will chirp and chatter and pump and breathe with your lower gain settings. After screwing around with gates for a while, I tried a variety of the Rocktron Hush units; these did not have the typical gate chatter, but they destroyed my high end and presence, so those were a no-go. Tangent: as I understand it, the ISP Decimator was designed by the team that developed the Hush circuitry. I've not personally played the ISP ped, but reports are overwhelmingly positive, so I have to speculate that it sounds and responds differently than the Hush units I played.
After the gates and the Hush unit gig benchtests, I happened upon the BOSS NS-50 half-rack unit, and later, the NS-2 stomp. Here at last was a unit that would tame my single coil noise and gainer hiss without stomping all over my base tone, dynamics, and sustain, regardless of gain settings derived from other sources. Sold. That's what I settled in with, and have been using ever since.
Back to the NF-1. I used it at a club gig years ago. I set the sensitivity to deal with my highest gain settings, and I remember going to a clean tone for a cover of the Moody Blues' "Nights in White Satin", and the circuitry clipped my signal to the point of embarrassment. It's a gate, not a suppressor.
- BB
Old July 7th, 2008, 05:25 PM   #18 (permalink)
franchelB's Avatar
I don't use a noise gate for a guitar because I have an effects loop in my Peavey Delta Blues. I do use a compressor "in front" so there IS a bit of noise, but not enough to bother me. I do use an old 1/2 rack mount Boss RCL-10 in the effects loop for my bass rig though.
Anyway, a noise gate might not be a bad idea if you don't have an amp with an effects loop.
Feel free to visit my homepage!
http://www.myspace.com/francisbalagtas
franchelB is offline   Reply With Quote
