Pedal Board Power
I've heard that the on-board power strips on most pedal boards add noise to to your rig. Is this true, because I just bought one and I have'nt been able to try it yet. Thanks.
| Sponsored Links |
Unless there's an actual defect it should add any noise. However, those power strips are nothing fancy, so they won't do anything to help suppress it.
You might find that you're fine. You might find that you have some pedals that would really rather have a transformer-isolated power supply to reduce noise. That's my one gripe with the Line6 Tone Core series. Unless they're on an isolated power supply they induce some obnoxious hum.
my blog: eryque.blogspot.com Updated 9.17.08! Subscribe_____________________
A Voodoo Labs Pedal Power II won't add any noise. Highly recommended. http://www.sweetwater.com/store/detail/PedalPwr2Pls
Wish my father gave me pedal boards. He's still trying to figure out why I had to spend a hundred dollars on a tuner.
USA Ovation * (Big Baby Taylor - SOLD) MIM Telecaster * Vox AC15CC Takamine Classical G series Martin 000C-16RGTE Aura Some people sing in the shower, I play guitar... |
Power supplies like the 1Spot don't have isolated outputs, so if one of your pedals is producing excess noise it'll be fed on down the line, whereas with the Pedalpower2 or other isolated supply that noise will be, well, isolated.
http://www.jimdunlop.com/index.php?p...p_and_e_detail
I use the Dunlop Brick. It's my all-time fav power supply. Johnny Isaacs
Myspace music page I've never trusted a guitar player who hasn't licked a few 9volts... Famous last words...... after this one, no new Tele's! |
I have been using a 1 spot for quite a while to power 5 or more pedals at a time. IT works fine, maybe the pedals I have are just quiet.
But I want to switch over to the Pedal Power 2, so I can add sag to my Fuzz. The isolation of circuits is something else I'm interested in, but doesn't seem to be a total requirement for my current selection. If you're asking about just putting a surge suppressor or cheapo power strip actually on your board? Well, I dunno if it'll add noise or not, but I would think it would add a lot of bulk... strip and all those wall warts. I do use a good quality surge suppressor to plug all my stuff in. I like buying the 'audio grade' ones... Just makes me feel better.
John F. TDPRI # 1764 |
Do you mind if I hijack this thread for a moment?
I also need advice on pedalboard power supplies.
I posted a thread recently about a new device that Radial Engineering have supplied me to power my Switchbone. Well, I've installed it onto my pedalboard and added a power supply which is specifically designed for powering 8 Boss-style pedals. My plan and expectation was that I could use two of the daisy chain power leads supplied with the BCB-60 and power the Tailbone (takes two 9v power leads and converts this to 15v) but the daisy chain doesn't provide two isolated 9v so I had to use a separate power supply. I tried a "Power Block" from my local guitar shop (has 5 9v power outlets) but I had exactly the same problem - it doesn't supply two isolated 9v supplies so wouldn't even power the Tailbone. So I purchased a Power Block from my local Maplin (the UK's equivalent of Radio Shack) and this does power the Tailbone but NOT the rest of the pedals. As soon as I plug in another 9v cable to the adjacent pedal, nothing works. So I'm having to power the Tailbone from the 8-outlet Power Block and power the rest of the pedals:
![]() It works fine but I still need two plugs to power the board and I presume it's because most power supplies don't provide isolated 9v supplies? Any thoughts, suggestions or ideas how I might get this to work with one plug. Radial Engineering have been great but allowing me a prototype helps them get it field tested without too much hassle. Thanks in advance.
#13 (permalink) | |
ΜΟΛΩΝ ΛΑΒΕ |
#14 (permalink) | |
I think I got this for him when he was either 10 or 11. I don't remember exactly...
Best guitar photos on the net! photoweborama.com! |
#15 (permalink) | |
Ed Mailhot Modded Squier Vintage Mod now w/4-way and gfs pickups Aria Ad-28c W/b-band nady wireless Vox DA-15 &Crate Palomino V3212 |
#19 (permalink) |
Thats cold. I know a kid, super at guitar real genius, who plays metal and likes the band trivium. His dad heard the guitarist was selling his guitar on ebay and shelled out 4000 bucks for it. Les paul Custom EMG's etc.
#20 (permalink) |
Peter, what you need is a power supply with transformer isolated outputs. The only 2 that I know of are the Voodoo Labs Pedal Power series or the T-Rex.
The reason it isn't working with what you have is because you're not using isolated power supplies. The two plugs you're using are part of the same circuit and are connected electrically, so you're really only plugging 9V into the input side of that switch. If your Tailbone can handle 18V, you can use 2 outputs of the Pedal Power and a special cable to make 18V.
#21 (permalink) | |
Thank you for the reponse.
#22 (permalink) |
When it was a couple pedals in a bag, set up on the fly, I always used the Godlyke Powerall. Excellent product, did what I needed and never gave a problem. Then I started using two larger pedals (Van Amps Sole Mate reverb, H&K Replex delay) requiring dedicated 12 to 13 volt AC power supplies. The hassle factor got too much, so I picked up a used pedal board (trailer trash) with the pedal power II already installed underneath. That takes care of my DC pedals. Rather than continue to mess with walwarts, I bit the bullet and got the PP AC unit, put that under there too. These two things add weight, no doubt. But they are utterly reliable, completely silent. It was so worth the money.
#23 (permalink) |
I just bought a Pedal Power 2 - bloody expensive in the UK (£159) but worth every penny. Does not come with enough longer power leads - if you are powering 8 pedals, even in two rows like I do, there are going to be a couple that are a bit of a stretch.
It is actually the most expensive thing on my board but works great with Boss , MXR, Voodoo Lab (of course) and my self built pedals from BYOC. I have also seen the BNIB Burkey Flatliner Pro Pedal Board Power Supply and Artec units on ebay that have isolated outputs. The Artec unit only had a two pin plug which put me off in the UK though they said it would work with 240v. |
#24 (permalink) |
I use the Soundlab thing Peter has without problems , as my pedals have average requirements .
Cost me about £16
Homepage http://www.soundclick.com/members/de...member=flat357 MySpace http://www.myspace.com/flat357 |
