Old May 6th, 2008, 01:40 AM   #1 (permalink)
monfoodoo's Avatar
Tsunami outputs
I just recieved a rocktron Tsunami,but no manual.Can someone explain the two output differences?
monfoodoo is offline   Reply With Quote
Old May 8th, 2008, 11:31 PM   #2 (permalink)
monfoodoo's Avatar
They are marked D+E and D-E.What is the difference?
Old May 9th, 2008, 11:53 PM   #3 (permalink)
monfoodoo's Avatar
No takers?or am i suppose to know the answer?
Old May 10th, 2008, 12:42 AM   #4 (permalink)
BrianF's Avatar
I'll take a guess D is direct E is effect... D-E is Direct plus effect -180 degrees out of phase and D+E is Direct plus effect +180 degrees...sort of simulated stereo with out of phase signals.. thats my guess.
Old May 10th, 2008, 06:15 AM   #5 (permalink)
telel6s's Avatar
Did you think of looking at the Rocktron website?
Originally Posted by Rocktron.com
Utilizing both outputs in stereo produces a very wide effect in both modes. Guitar Shop Magazine said: "A very interesting feature (and one that might be overlooked if not fully explored) is the unit's output section. It has a single input and two outputs much the same as most "stereo" chorus units. The difference here is that one output puts the effect in phase with the dry signal, while the other gives you the wet and dry signals out of phase. With the dual outputs, when used in stereo—either through a mixing board or with two guitar amps—the combination of in- and out-of- phase effects together provides something very special. Your run-of-the-mill chorus unit's stereo output will not provide this degree of colorful spatial manipulation. Also, be sure to try both outputs even when using the box in mono. You can achieve cool, subtle differences using one output or the other.
Mama always said, "A little tone is good for the soul."
telel6s is offline   Reply With Quote
Old May 10th, 2008, 07:45 AM   #6 (permalink)
Wardpike's Avatar
Corrrect. Common conventions are:
D = Direct uneffected sound
E = Effect generated by unit.
D+E=Direct plus Effect
D-E=Direct minus Effect. (of course, this is as you stated '180'º out of phase)
Old May 13th, 2008, 11:55 AM   #7 (permalink)
monfoodoo's Avatar
Thanks,i got it now.
vB code is On
Forums Directory
