If your using a boss TU-2 stompbox tuner you can just use that. Some say its not technically a power supply and may not power all 8. It really depends on the pedals your powering, that would help us.
USA Ovation * (Big Baby Taylor - SOLD) MIM Telecaster * Vox AC15CC Takamine Classical G series Martin 000C-16RGTE Aura Some people sing in the shower, I play guitar... |
Here's one:
http://www.zzounds.com/item--MAXSWM And a bunch more if you like choices: http://www.zzounds.com/item--BEHPB1000 |
Here's the one I use for my pedal board for all the 9 Vdc.
http://www.voodoolab.com/pedalpower_2.htm Not cheap, but works well. For like two or three pedals, this can be a good choice http://www.visualsound.net/1spotcombo.htm My son uses the 1spot and he likes it. One problem with the onespot is the potential for ground loops, but as a power supply, it is ok. Probably much like the Godlyke. |
I currently use a 1-Spot, which is affordable and pretty good, though lately I have been thinking about getting the power supply made by Gator:
As I have read some good reviews about it on websites other than MF, and it seems to be within my price range and needs.
RAMA LAMA FA FA FA |
#7 (permalink) | |
This is really interesting. My board has a TS-9, a TS-10 and a tuner. There are a couple of other pedals but they require their own power source. So how do you use the TU-2
![]() éí 'aaníígÓÓ 'áhoot'é Would you mind holding this bag while we go through the custom shop????? Redd Volkaert is a Jedi Knight at one with the Force!!! |
One-Spots are great....here you go man....8 pedal One Spot unit for $35.00.
JLG Carry On |
I have a smaller board (still adding) but al u need is a daisy chain which you can buy the roland one for like twelve bucks at GC. I dunno how many mine powers yet but I know when I try something bigger after a few pedals it doesn't work. pm with any questions.
I use a 1spot for the 5 or six pedals I ahve now. That's what works with the daisy chain piece that came with it. If I was gonna do more pedals than that, I'd be a little nervous about using the 1 spot and might go for a better one like the Voodoo Labs or similar.
If, like Gary I was only powering a couple, I'd use my TU-2. You just grab a daisy chain like goes with the 1Spot.
John F. TDPRI # 1764 |
Depends on the pedals. I used a OneSpot for a while but some were noisy so I ended up using a couple of separate power supplies for those which kind of defeated the purpose. I picked up a used Pedal Power and I tell ya, it's all it its cracked up to be. Well worth it if you're really serious about your sound.
I got the rockin' pneumonia, I need a shot of rhythm and blues! http://www.myspace.com/javablue |
#14 (permalink) |
8 pedals?
I would go with the Voodoolab Pedal Power 2 and be done with it. They work great- I have two (230v and 110v) and have been around the world with me- never had any issues.
"A jazz musician is a juggler who uses harmonies instead of oranges." Benny Green |
Been very happy with this chap's offering so far, plus a daisy chain... simple and well thought out.
http://www.diago.co.uk/ |
#17 (permalink) |
I been using the Visual Sound "1 SPOT" and couldn't be happier. It comes with everything but a "reverse polarity" plug and works on almost every pedal out there.
My signal chain this week is: GTR>Peterson SS2 tuner>Fulltone Fulldrive 2>Roger Mayer Voodoo One> Boss RT20 Rotary Simulator>MXR Carbon Copy>amp I will eventually upgrade at a later time but for the money it does the job just fine and no loss of tone.
"the cult aesthetic of liking only what's obscure is just as sick of being mindlessly led around by the nose" -Mark Mothersbaugh |
#18 (permalink) |
Might be overkill, but my pedalboard has both the Pedal Power2 and the AC pedal power unit. The board (trailer trash) came to me with the PP2 already mounted. I added the other unit to power an H&K Replex and Van Amps sole mate. One power supply plugs into the other, then one plug to the wall. Sure is convenient, though not light.
#19 (permalink) |
Hi folks, Andi here.
We use the PP2 for a number of reasons(regulated source, AC output, 12v, etc.), but have a OneSpot to fill for a few Boss pedals at times as well. Digital switching power supplies like the Diago, OneSpot, Artec etc are not regulated nor isolated, which means noise can happen along the way, namely with sensitive vintage-spec fuzzes(especially Fuzz Face variants) and some univibe clones. Some clock-based choruses and delays have been known to be introduced to noise along the way as well. The other potential issue with a digital switching type is the fact that if one is close to being overloaded you run the danger of getting a moment of hiss (i.e. circuit burn) and an explosive bang that may very well fry the entire Daisy chain...Although I've yet to disassemble one to see if the circuitry safeguards the output along the way. All in all, if it's quiet for you and you're powering way under 1.7amps of goodies, I wouldn't have a problem with them in general, but believe that $150 for regulated power source with a proper transformer in it is a nice investment that costs as much as many of us spend on a pedal, yet worth the whole board IMHO. |
#20 (permalink) |
I used my TU-2 + PSA-120 + daisy chain for a while, it works fine and I had no problems, but recently I got three more pedals with around 250ma, thats when I got a OneSpot. IMO its much better then the TU-2 method, the daisy chain is much longer and has right angles which helps with my pedalboard.
#21 (permalink) |
I liked the simplicity of the one-spot but had some noise issues.
I'm currently using a |
