Pres-set volume switching pedal
Nephew Andre (Rosie Ledet Band) needed a way to quickly switch from rhythm to lead without resorting to twiddling the guitar's volume knob.
Hmm, a bit of sketching and I came up with a simple passive switching circuit utilizing a pair of 500k pots, two jacks, a special 3PDT stomp switch, a battery clip and a pair of LED's (green and red) and the appropriate LED voltage resistors. A small cast pedal box competed the deal. The circuit itself is passive and the extra poles on the switch allowed the use of LED's to show which vol pot is selected. I layed out the components into the case for proper fit, drilled out the holes, and used some handy rattle can color spray on the box followed by a few spritzings of clear. Everything fit into the case nicely and wiring was easy ... ![]() Plugging a guitar in kicks on the battery to show what pot gets selected, run the box to any FX and on to the amp, preset each vol pots to the desired level, hit the footswitch for instant volume selection. Fun stuff.
| Sponsored Links |
dang, i've been wishing for something like that since 1973!
Truth is stranger than fact ... www.myspace.com/woodymitchellmusic BAND PAGES: www.myspace.com/stragglerswing (Stragglers - Western Swing) www.myspace.com/loafersgloryband (Loafers Glory - '70s country-rock) |
Rob, where would you put this in the signal chain?
Pots. jacks and 9V battery clip can be sourced from most anywhere, the resistors, LED's and LED holders are from Radio Shack, the special 3PDT switch and the case came from www.effectsconnection.com
Hooking up LED's is really easy. The longer lead is positive (hot) and the shorter lead negative (ground). In order to supply the proper voltage to each LED when using a 9v battery, apply the following formula to determine the proper resistor for each LED ... battery voltage minus LED voltage divided by LED milliamp draw 2.6v 28ma LED example ... 9v - 2.6v = 6.4v / .028ma = 228.6 ohms (or the closest higher value)
Hey Rob,
Why did you go with two pots? Why not just one pot: Pedal Off: Guitar straight through Pedal On: Volume pot sets lower level Also, is there going to be any tone changes if one of the volume pots is rolled way back (like on a tele without the extra resistor thingy on the volume pot)?
Mama always said, "A little tone is good for the soul." |
#14 (permalink) | |
There's always issues of passive units affecting tone (heck, that's also true of active circuit - and maybe more so with them!), and the original circuit had bleeders in both vol pots but I found that overkill for single coil guitars. Optionally, bleeders could be added on a switch and selected as needed (or not). So many options, the pedal can be tweaked for one's precise needs. Yer just a foot stomp away from "Heaven and Hell" or "Nice 'n' Nasty" |
