Old April 30th, 2008, 08:16 AM   #41 (permalink)
hal
hal's Avatar
Wierdest...
The Robotalk. But I don't use it very often.
Wherever you go, there you are.
hal is offline   Reply With Quote
Old April 30th, 2008, 04:22 PM   #42 (permalink)
I have two pretty weird ones:
I, too, have the Alesis BITRMAN that kingnimrod posted back in this thread.
The other box is a Mobius, an endless looper - it takes whatever effect(s) you have plugged into it and loops it back on itself, over and over. Needless to say, that leads to some VERY far-out weirdness.
bowman is offline   Reply With Quote
Old May 19th, 2008, 02:25 AM   #43 (permalink)
Aen
Aen's Avatar
Whew, I;ve got a few. EHX Pog, Moog Freqbox, Dwarfcraft Power Struggle/Great Destroyer, Effector 13 Disaster Fuzz....
Alt-country and psych-rock-tronica! Hey, be happy you can choose one genre for yourself!
http://www.myspace.com/aenpage
Aen is offline   Reply With Quote
Old May 19th, 2008, 02:50 AM   #44 (permalink)
I dont use many...but here is a picture of almost my current board..still changing things ...I plug right into my amp more often than not...but the weirdest thing Ive used on any regular basis is that little green box in the corner..the digitech synth wah...for Jerry Garcia-esque mu-tron type auto wah sounds....does a surprisingly good job.
thats a 1977 New York Small Stone there too..kind of cool.
CatfishStudios is offline   Reply With Quote
Old May 23rd, 2008, 04:07 PM   #45 (permalink)
Pacafeliz's Avatar
my weirdest ones are:
coron space machine
and the Fender Dimension IV box (no pic here)
Pat.
...proud Squier user and abuser!
www.myspace.com/pacafeliz
Pacafeliz is offline   Reply With Quote
Old May 29th, 2008, 08:16 PM   #46 (permalink)
aberrant's Avatar
Could we get a Tambourine vs. Squawking Owl cage match to the death?
aberrant is offline   Reply With Quote
Old May 30th, 2008, 12:39 PM   #47 (permalink)
txjeff's Avatar
I think that would be sort of like pitting Simon and Garfunkel against Grand Funk Railroad.
txjeff is offline   Reply With Quote
Old May 30th, 2008, 01:14 PM   #48 (permalink)
Beatbx's Avatar
Originally Posted by txjeff View Post
The "Owl" ,homemade by me around 1972, consists of a variety of 1970s effects and some homemade electronics that were changed out along the way. It has a homemade regulated power supply and you have to appreciate the frugal nature of the design using an old Vacuum Cleaner power cord. The case was handmade and took me 4 hours to make out of plywood, hardware, cut out with a circular saw, and painted. The S.O. box itself was this steel chassis with no bottom. I had to make the bottom out of a piece of plywood with sheet metal cut and attached. Shielded coax was used to run the inputs/outputs. The hardest part is doing lettering. These were the days when they were like decals that you would rub on from waxed paper. And then I clear coated it like 10 times!
Inside you have 70s Electo Harmonix Big Muff Pi(Fuzz), Electric Mistress (Flanger), Small Stone (Phase Shift); Octave Multiplexer. Notice that the Big Muff has a special selector switch, with cap switching, that suppresses the distortion to make it less "fuzzy". Also there is a "fuzz before phase" or "phase before fuzz" switch, that flips the order of the two making two distinctive sounds. Fuzz before phase gives a deep swirling phase, and the other gives a more subtle blend (which I prefer).
Originally I had a cheesy lowpass and highpass filter that wasn't used often. But then, years prior, I found this great circuit for a "Guitar Tone Enhancer" in Popular Electronics (of all places). A simple circuit but well designed. In addition, I modified the gain section so it would overdrive. Originally I had this in a small box with a jack that could plug directly into the guitar (I still have that one). So I decided to build a second one and put it in the Owl.
Lastly, I used an Echoplex years ago and needed a local bypass footswitch, so I added one with an extra jack.
The things that need fixing: The Octavizer went out so I bought another one but I've yet to swap it out. The power supply needs updating to a more modern quieter one. I might change the Flanger out with a Flange/Chorus.
I always hated old fashioned klunker switches. Half of them would 'pop' the circuit. I always wanted to switch it to FET circuits that would be silent with some quiet action foot switches. AND, the bending to adjust the tones was always pretty silly. I'd rather have a lengthy cable to the footswitches and the knobs up high at around stomach height (maybe on a music or mic stand affair).
Gee I wonder if I can still find the wiring diagram? Maybe I'll follow through and redo the whole thing some day.
That's damn impressive. I think we have a winner!
Beatbx is offline   Reply With Quote
Old May 30th, 2008, 02:08 PM   #49 (permalink)
blowtorch is offline   Reply With Quote
Old May 30th, 2008, 02:20 PM   #50 (permalink)
Do auto wahs, like the Digitech or the EHX Q-tron, work well with Teles? I have heard great things about these pedals, but I have heard some mutterings that they do not produce their best sounds out of a Tele. Does anyone use these with Teles to a good degree of satisfaction? If so, I'm getting one of these things.
Robsocal is online now   Reply With Quote
Old May 30th, 2008, 02:37 PM   #51 (permalink)
txjeff's Avatar
Originally Posted by blowtorch View Post
Wow. Now that is cool looking and mysterious because it has no words.
You gotta expand on that one! (And I mean no words above the knobs and no words in the details!)
Is this a "name that pedal" test?
Old May 30th, 2008, 04:29 PM   #52 (permalink)
missfortune's Avatar
As the owner of the Tambourine, I can confidently say that even the plywood case that the Squawking Owl sits in could destroy my humble little Mississippi Drum Machine....
Peace,
missfortune
http://www.soundclick.com/professorf...ightycowwolves
missfortune is offline   Reply With Quote
Old May 30th, 2008, 07:10 PM   #53 (permalink)
txjeff's Avatar
Old May 30th, 2008, 07:15 PM   #54 (permalink)
Works fine with my Tele..
Old May 30th, 2008, 09:15 PM   #55 (permalink)
Thanks for the tip CatfishStudios. I'll head out this weekend to a/b the EHX Q-tron and the Digitech model. Then I'll have to learn Estimated Prophet, Shakedown Street, and the Dead's version of Dancin' in the Street (think 1st set closer - Cornell 1977). Wah on.
Old May 31st, 2008, 01:09 AM   #56 (permalink)
austintele's Avatar
boss slow gear
austintele is offline   Reply With Quote
Old May 31st, 2008, 10:22 AM   #57 (permalink)
franchelB's Avatar
Originally Posted by Big Tony View Post
The old "Korg ToneWorks 411fx Super Multi FX", from 1997. Guitar Player gave it a really bad review at the time. I've been using it, on and off, for over 10 years . I find it very useful, and sometimes use it in place of individual stomp boxes. I guess you just got to know how to "tweak it"!
/ Tony
I forgot about that one! I also have one that crapped out on me. I can only use the presets now...so I don't even use it anymore.
As for my gear, the "weirdest" pedals I use are my dynacomp, crybaby, and digidelay...I just don't know how to use it "properly.
Feel free to visit my homepage!
http://www.myspace.com/francisbalagtas
franchelB is offline   Reply With Quote
Old May 31st, 2008, 10:39 PM   #58 (permalink)
kp8
kp8's Avatar
Tonefactor Ultralord
Just sold a couple pedals and scored this (mint & pretty darned cheap too) with the paypal i saved up. I have wanted one a while now. This is a total meltdown pedal -- a hide the children, buildings loosing pieces of brick type pedal. I love it so far. It is totally evil.
Old May 31st, 2008, 10:40 PM   #59 (permalink)
kp8
kp8's Avatar
Old May 31st, 2008, 11:21 PM   #60 (permalink)
my Hybrid TS9 & Expression Pedal for sure.
product26 is offline   Reply With Quote
Old May 31st, 2008, 11:56 PM   #61 (permalink)
Does a good Fire on the mountain too...go get your Jerry on!
Old June 1st, 2008, 12:12 AM   #62 (permalink)
Paul in Colorado's Avatar
coron space machine
Pat.
OK, what does a Coron Space Machine actually do? And isn't the Dimension IV an oil can echo or something else?
www.tuatha.net
Old June 1st, 2008, 12:22 AM   #63 (permalink)
Originally Posted by JonnyM View Post
The trick is thus: Never use the Boost! LOL. Morley has a different take on how to do Wah, but I like it, the optical circuit thing or at least I'm used to it and know how to deal with it. The volume pedal side is also great for those violin slow attack sounds, you can really get scary weird with no attack and some serious delay and modulation happening.
Just remember never ever use the Boost! It's not musical, it's just noisy bad.
I had one of those back in the '70's. Only I did use the boost. Sweeping the wah with all the hiss from the boost was perfect for that waves on the sea shore sound that we used at the beginning of "Wooden Ships" and an original called "Ocean Song." Our bass player was able to rub on the strings in a way that sounded like the ropes from the dock to a ship stretching.
www.tuatha.net
Old June 1st, 2008, 07:16 AM   #64 (permalink)
idoru's Avatar
It's modern, inexpensive & quirky: the Ibanez PM-7 Phase Modulator. Does standard phase sounds, a square-wave phase & hi-frequency modulation which can sound a lot like a ring-modulator. Excellent little noise-box!
c-
idoru is offline   Reply With Quote
Old June 1st, 2008, 01:07 PM   #65 (permalink)
59TweedVibrolux's Avatar
