Old April 6th, 2008, 02:44 AM   #1 (permalink)
garytelecastor's Avatar
Just Clean boost
Over the past couple of weeks there have been some posts on here about the best clean boost pedal that everyone likes. I have been using an EQ for a while and I thought I would try something different.
In some of the pedals that were recommended I went to their web sites and they have recorded samples. The problem is they all are distorted. None of them have a clean signal to begin with.
I very rarely use distortion and I would like to know if there are some boost pedals out there that aren't disguised overdrive pedals. Anybody know of a good clean boost without coloring the tone?
éí 'aaníígÓÓ 'áhoot'é
Would you mind holding this bag while we go through the custom shop?????
Redd Volkaert is a Jedi Knight at one with the Force!!!
garytelecastor is offline   Reply With Quote
Old April 6th, 2008, 10:37 AM   #2 (permalink)
I just recently picked up a Catalinbread Super Chili Picoso and I am very pleased with it.
Filthy McNasty is offline   Reply With Quote
Old April 6th, 2008, 11:33 AM   #3 (permalink)
Big Lug's Avatar
Originally Posted by garytelecastor View Post
... Anybody know of a good clean boost without coloring the tone?
Bad Bob.
Period.
'Nuff said.
"Set my compass North I've got winter in my blood." Robbie Robertson
Big Lug is offline   Reply With Quote
Old April 6th, 2008, 12:28 PM   #4 (permalink)
Nub
The Bad Bob does add a fair amount of grit as you turn it up; it's a great sounding pedal, but it definitely puts it's own character on your sound. The pedal that knocked it off my board is a Flying Dragon clean boost; it doesn't color my sound at all, stays clean, and stacks much better with other OD's:
http://lizardlegeffects.com/dragon.html
Nub is offline   Reply With Quote
Old April 6th, 2008, 02:37 PM   #5 (permalink)
andrenighthound's Avatar
i bought a barber launch pad 2 weeks ago and even though i play low headroom amps, the launch pad sounds just like my amp. clean boost. i don't hear any color coming from it.
i have a twin, but didn't get a chance to try it on that amp.
i hear a person can use the launch pad pedal to "cook" an amp, as well as a bunch of other things.
"Blues in a doggy bag, is what I got to eat!"
www.andreandthenighthounds.com
andrenighthound is offline   Reply With Quote
Old April 6th, 2008, 05:15 PM   #6 (permalink)
Does anybody know anything about the MXR MC-401 or the Artifact 25 by Effector13?
Old April 6th, 2008, 05:55 PM   #7 (permalink)
tazzboy's Avatar
Well here is the MXR one
tazzboy
Old April 6th, 2008, 06:06 PM   #8 (permalink)
Thanks tazzboy. These are the guys that I was referring to in the original post. It seemed that they had every review of a clean boost with the guitar so distorted by the amp you couldn't hear the pedal do its job.
Old April 6th, 2008, 11:37 PM   #9 (permalink)
RomanS's Avatar
Have you tried an Electro Harmonix LinearPowerBoost? Stays clean almost all the way (except with high output humbuckers) - but it does indeed slightly color/fatten the tone of your guitar...
RomanS is online now   Reply With Quote
Old April 7th, 2008, 11:15 AM   #10 (permalink)
Axis29's Avatar
Hey GaryTelecastor,
How much boost are you looking for?
I looked all over the place for a clean boost for a long time, then picked up a TS, and used it with the gain down and the volume up. That worked pretty well. Then I sold my Mesa and bought a DRRI and everything changed. Now I use the TS for a little grit and I use the guitar's volume knob to adjust the actual volume of my playing (for solos and such). I love this setup.
John F.
TDPRI # 1764
Axis29 is offline   Reply With Quote
Old April 7th, 2008, 12:35 PM   #11 (permalink)
I love the Juaernig Luxury Drive. It's very clean, at least at the level of boost that I use, and just makes everything sound better. I hear a slight boost in the highs, but that may simply be the volume. I rarely turn mine off.
John
John Thigpen is offline   Reply With Quote
Old April 7th, 2008, 01:23 PM   #12 (permalink)
kp8
kp8's Avatar
For clean boost (w/headroom) i use an MI Audio Boost 'n' Buff.
It has a whopping 35db of boost on tab. The first 12-16db of that is pretty darn clean. It is very quiet, and it has a ultra high input impedance buffer (5Meg!). You can run it on 18V for lots of headroom.
Run it first in my chain.
for boost with more grit to it... i use the bad bob (which i love).
Old April 7th, 2008, 01:30 PM   #13 (permalink)
FMA
Lot's of good suggestions. Bang for buck, I like the BBE Boosta Grande. Lots of clean boost and very transparent and quiet...
FMA is offline   Reply With Quote
Old April 7th, 2008, 01:42 PM   #14 (permalink)
62_Inca_Esquire's Avatar
The "cleanest" boost will be one that uses a hi fidelity op amp run at more than 9v (i.e 18v) for greater headroom /voltage swing. Pedals like the Barber Launch Pad and the MK.4.23 Boost fit into this category.
Fets, Mosfets, etc have more potential to alter the original tone.
That being said, running a mosfet boost (like the AMZ or SCP) at 18v can also give you a great "mostly"clean boost. Check to make sure that the pedal you choose can indeed be run at 18v.
Finally...let me just say that 99.9% of people don't actually "want" a clean boost. They don't want a "straight wire with gain" type tone...they want something that enhances the signal, and makes it fatter, warmer, rounder, brighter, etc, etc, etc.
62_Inca_Esquire is offline   Reply With Quote
Old April 7th, 2008, 02:38 PM   #15 (permalink)
Chito's Avatar
+1 This pedal doesn't get a lot of attention. Maybe because of the size or maybe the look doesnt appeal to most folks. But as mentioned, it doesn't colour your tone at all and very quiet.
www.mosayk.ca
Chito is offline   Reply With Quote
Old April 7th, 2008, 02:56 PM   #16 (permalink)
Another Boosta Grande user hear... Great Clean boost with little to no color... I Used to use a MXR Micro amp boost pedal but it is just to noisy for my taste
giogolf is offline   Reply With Quote
Old April 7th, 2008, 08:45 PM   #17 (permalink)
rythmpyg's Avatar
+ another barber launch pad
http://www.barberelectronics.com/LaunchPad.htm
rythmpyg is offline   Reply With Quote
Old April 7th, 2008, 08:53 PM   #18 (permalink)
stxrus's Avatar
check out the Reinhardt Hitman A/B/Y with Cleasn Boost.
bob has a good pedal that with a fairly transparent, at least to my ears, boost.
i've got one and have removed almost everything from my board.
steve
stxrus is offline   Reply With Quote
Old April 7th, 2008, 09:26 PM   #19 (permalink)
Ethical's Avatar
If you don't want to colour your sound then adjusting your amp and guitar volume controls works really well. Of course it will depend on your amp but try increasing the volume (not gain) on your amp and backing off the volume on your guitar to get your "normal" level then you can open up your guitar volume for when you want to wail.
Ted
If it wasn't for bad luck, I'd have no luck at all
Ethical is offline   Reply With Quote
Old April 7th, 2008, 09:27 PM   #20 (permalink)
Wow. Thanks you guys for all the suggestions. I run my guitar into a Carl Martin Comp into a TS9 into a TS10. I just wonder if there is a correct spot for it on the board? I know Kp8 said he puts his first in the chain but I just really want to take my clean tone and push it up for solos.
Old April 7th, 2008, 09:44 PM   #21 (permalink)
rythmpyg's Avatar
as you can see, i run it at the end of my chain (goes right to left)....it boosts whatever pedals are "on" in front of it....as such, when no dirt pedals are on, its pure clean boost...and the launch pad (if you can see the settings) has a lot more boost than i've ever needed in obnoxiously loud bands....buy it from someone with a 30-day return policy....no big woop
Old April 7th, 2008, 10:27 PM   #22 (permalink)
franchelB's Avatar
It's your money...
In some of the pedals that were recommended I went to their web sites and they have recorded samples. The problem is they all are distorted. None of them have a clean signal to begin with... Anybody know of a good clean boost without coloring the tone?
I've heard the Keeley's Katana. It definitely needs to be heard to be believed. But really, I see nothing wrong with using a regular EQ pedal.
Feel free to visit my homepage!
http://www.myspace.com/francisbalagtas
franchelB is offline   Reply With Quote
Old April 7th, 2008, 11:03 PM   #23 (permalink)
Seymour Duncan Pickup Boost has worked for me. Gives my Tweedy Champ a lot more clean to slightly hairy headroom. Never use the EQ filtering that is supposed to make a single coil sound like a HBer ( it doesn't, but boosts mids). It has 25db of gain.
Brick is offline   Reply With Quote
Old April 8th, 2008, 01:36 AM   #24 (permalink)
tazzboy's Avatar
Seymour Duncan Pickup Booster SFX-01
tazzboy
Old April 8th, 2008, 01:52 AM   #25 (permalink)
Thanks again for the vid Tazzboy. From what I was able to gather from the vid the pedal kind of acts as a Humbucker simulator. Am I on the money?
Old April 8th, 2008, 02:07 AM   #26 (permalink)
tazzboy's Avatar
That's what the Narrator said.
tazzboy
