Old March 25th, 2008, 02:25 PM   #1 (permalink)
CIM
CIM's Avatar
Any Lower Cost Ross Compressor Clones out there?
I like the Ross compressor sound a lot - in fact I have an old 80's Guyatone which is an accurate clone of the original ross compressor circuit and sounds great, but I'd like a more robust backup and so wondered which currently available pedals outside the Keeley/Analogman boutique zone are essentially a clone of the original Ross design?
I know the dynacomp is a very similar circuit - but I used to own a script dynacomp and I still much prefer the Ross character.
Any ideas?
CIM is offline   Reply With Quote
Old March 25th, 2008, 02:41 PM   #2 (permalink)
Moderator
getbent's Avatar
build a byoc. you can make a ross clone for like 75.00
'never pet a burning dog'
Old March 25th, 2008, 02:51 PM   #3 (permalink)
CIM
CIM's Avatar
Yes thanks, I am aware that is an option. I have built a few pedals in the past - although when you factor in the time it takes I would not personally consider it worth taking that route primarily to save money.
Anyway - what I would like to know is whether there are any mass produced pedal available today which are based on the Ross circuit.
Old March 25th, 2008, 03:11 PM   #4 (permalink)
Moderator
getbent's Avatar
only analogman and axeandyoushallreceive.com to my knowledge....
with a little research I found that the Barber Tone Press is a Ross variant.
Old March 25th, 2008, 03:27 PM   #5 (permalink)
Chito's Avatar
The GoudieFX Compressor is a Ross clone and much more affordable than the Keeley. Excellent pedal. I've had mine for over a year now.
http://www.goudiefx.com/compressor.php
Here are the reviews:
http://reviews.harmony-central.com/r...ompressor/10/1
www.mosayk.ca
Chito is offline   Reply With Quote
Old March 25th, 2008, 10:32 PM   #6 (permalink)
Ross compressor
I have a Ross compressor from the 80's. I didn't know they were even worth anything. I'll have to dig it out and use it again.
hiwannajam is offline   Reply With Quote
Old March 26th, 2008, 09:33 AM   #7 (permalink)
CIM
CIM's Avatar
Aha, that's an interesting one, I had a Tone Press for a while (I have owned more compressors than is probably healthy in one lifetime, mostly courtesy of eBay) but I preferred my old Guyatone and did not consider the Tone Press to sound the same. I know the Tone Press has a blend control but 'unblended' I suppose it should sound the same as a Ross if it is indeed a 'clone'.
Maybe the old 3080 IC's were a bit different sounding, who knows...
I do know my old Ross clone is not the quietest - but that is only evident if you crank the sustain to beyond what I would consider sensible levels - otherwise it is quiet enough for me.
Old March 26th, 2008, 05:00 PM   #8 (permalink)
ramseybella's Avatar
http://cgi.ebay.com/BONEPICKER-BONE-...QQcmdZViewItem
ramseybella is offline   Reply With Quote
Old March 26th, 2008, 06:01 PM   #9 (permalink)
What about Retro-sonic??
eom
.....and that's why keith richards cannot be killed by conventional weapons.....
Jerry J is offline   Reply With Quote
Old March 26th, 2008, 07:01 PM   #10 (permalink)
CIM
CIM's Avatar
Originally Posted by ramseybella View Post
He says "The pedal circuit in this pedal is custom designed" which does not sound like a Ross clone to me.
Old March 27th, 2008, 03:00 PM   #11 (permalink)
guit30's Avatar
Most Ross clones are modded , like the keeley has a ton of mods done to it, I couldn't believe how many parts it had, a double sided pcb board with compenants filling both sides, it had more parts than Analog Mikes Bicomp, which is on a single side pcb, Aesthetically, I love that sort of metallic Chrome finish of the Keeley, Almost as much as the incredible tone,
J
DOD FX80B Compressor
Hartman Compressor
Jim's Country Reviews
www.geocities.com/guit30
guit30 is offline   Reply With Quote
Old March 27th, 2008, 06:44 PM   #12 (permalink)
CIM
CIM's Avatar
J
There's a lot of difference between 'Custom Designed' and using higher quality components e.g. metal film resistors and high quality caps, bright white LED's, double sided PCB's and true bypass for example.
And last I checked, the case appearance made no difference to the tone
That said, I'd like a Keeley and I'm sure they are great, but they are very expensive in the UK. As I understand it, the Keeley design ethos is a higher fidelity version of the Ross, but I am personally not looking for higher fidelity, my Guyatone Ross clone is not lacking in tone quality for my purposes, just perhaps longevity - it is a 20 year old pedal which has seen a lot of use.
The premise of my original question was that I can live without the best quality components if the basic sound of a Ross is there - and given that so many people admire the Ross over its peer the Dynacomp, it seemed likely to me that some cheaper pedals might be basically Ross clones.
For example - I believe Behringer make an inexpensive Dynacomp clone for example (about £20 in Uk which is around $40) - which might have been OK for me had it been a Ross clone instead. I assume it is a Dynacomp rip-off because they call it a DC9...
Old March 27th, 2008, 06:51 PM   #13 (permalink)
photoweborama's Avatar
I have an Dulop MXR DynaComp. it was cheap, and it sounds great if you don't squash it too much... Oh, and I have an original script dynacomp...I like it too!
Best guitar photos on the net!
photoweborama.com!
photoweborama is offline   Reply With Quote
