thoughts on overdrive pedals transparent to amps - Telecaster Guitar Forum
Old March 18th, 2008, 12:50 AM   #1 (permalink)
andrenighthound's Avatar
Hello y'all,
I was wondering what people are using as an overdrive pedal to get a true, transparent sound of their amp.
I'm currently using a barber ltd with champster amp 5f1 circuit. It sounds really good, but I'm always looking for better!
Will a booster pedal give me what I'm looking for? If so, which one?
"Blues in a doggy bag, is what I got to eat!"
www.rosieledet.net
www.myspace.com/andrenighthounds
andrenighthound is offline   Reply With Quote
Old March 18th, 2008, 05:20 AM   #2 (permalink)
johnnykf's Avatar
My Fulltone GT500 is more transparent than the Fulltone FD2Mosfet I also have. Very versatile pedal
johnnykf is offline   Reply With Quote
Old March 18th, 2008, 05:35 AM   #3 (permalink)
Analogman King Of Tone
Regards,
Ray
Ray G is offline   Reply With Quote
Sponsored Links   #
Old March 18th, 2008, 06:25 AM   #4 (permalink)
I don't know about transparent. I just got a Barber LTD (the black one) and it makes my Champion 600 sounds much better than the amp alone ever could with my MiM Standard with CS Nocasters. All you have to do is play a few minutes with the LTD and then bypass it and turn up the amp volume to compare the amp's grit to the pedal's. No contest.
Maybe with some amps you don't quite want the true sound of the amp.
ON HIATUS
Brent Hutto is offline   Reply With Quote
Old March 18th, 2008, 06:39 AM   #5 (permalink)
ruger9's Avatar
I've been thru a ton of ODs, and usually "transparent" means "no mid hump." Out of all the ODs I've used over the years, the 2 that I think are most transparent & still have are:
Barber LTD SR - HAS to be the SR version. The different versions of the LTD are quite different.
Blues Driver - Keeley Modified. I don't even like the stock Blues Driver, but Keeley's mod is fantastic.
As far as tone shaping, the LTD SR has a very active tone pot, as well as Bass & Presence trimpots inside. The Blues Driver has a "Phat" switch (a mild bass boost, which I leave ON ALL the time), and the standard tone knob.
Both are great, and both are a tad more transparent than the FD2 in FM mode, altho I think the FD2/FM Mode is a great almost-transparent OD as well.
Thye LTD SR, if I had to pick one, is the "most transparent/most flat-EQ" of the bunch.
Old March 18th, 2008, 07:08 AM   #6 (permalink)
markinlondon's Avatar
Boss Blues Driver (stock) does it for me but you have to be very careful with the tone control.
Helping to invent english country dance guitar since 1981.
markinlondon is offline   Reply With Quote
Old March 18th, 2008, 07:53 AM   #7 (permalink)
I'm using a Fulltone OCD with my Mesa Roadster and find it really transparent.
I'm also using my Blues Driver as a clean boost. It was modded using the H2O mod kit from Monte Allums, and much more transparent than the stock version IMO.
((( KoskineN )))
KoskineN is offline   Reply With Quote
Old March 18th, 2008, 09:21 AM   #8 (permalink)
xjazzy's Avatar
I bought the SD twin tube for the transparent factor. I love it.
Still got the Twang!
https://soundcloud.com/jotacaster
xjazzy is offline   Reply With Quote
Old March 18th, 2008, 11:56 AM   #9 (permalink)
TeleBrew's Avatar
What about an MXR Micro Amp?
We never let the music get in the way of our stage show.
-Pete Townshend
TeleBrew is offline   Reply With Quote
Old March 18th, 2008, 12:07 PM   #10 (permalink)
tweedtone's Avatar
Tonefactor Copperhead is my new go-to boost 'n' drive pedal. Love it, love it, love it then I love it some more.
tweedtone is offline   Reply With Quote
Old March 18th, 2008, 12:52 PM   #11 (permalink)
Telenator's Avatar
Absolutely the best I have ever heard.
I don't use this pedal as a solo boost however. I use it as a 3 stage device to get my amp a bit louder and crunchier, (not much), to create the sound I need without having to touch the amp. If I need a weaker, single coil sound, but don't want it to get lost in the mix, I just tap the right switch. For those wonderful #2 and #4 positions on a Strat to be heard amidst the noise and confusion, I tap the left swithch. And when rich, thick, creamy sustaining OD is the order of the day, I tap both switches and engage the TS9. It sings and cries and never sounds thin or buzzy. mmmmmmmmm, KoT
As a seperate OD pedal for use as a solo boost, I think it's horrid.
Replacement WRHB Wide Range Humbucking pickups and modifications. Yes, we've got the CuNiFe. Telenator®
www.telenator.com
www.chruler.com
» Random Photo for Guests
pre assembly
» Recent ThreadsGuests
Fender Logan Custom Guitars
