| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
#21 (permalink) |
![]() Friend of Leo's
Looks good, Herb. Everything is in the right place. Orientation of e-caps is correct. Bus looks good.
Just check your solder joints. Make sure you can't pull them out by tugging on them. The back of the board looks a little light on solder in the holes. That indication alone doesn't mean the joint is not good. You be the judge. The back of the board is a nuisance to access - once you have everything buttoned down. New builders sometimes leave some cold joints back there which will break loose as you know. You can see and feel a great joint when it happens. Ideally, you want nicely domed joints which are the product of hot flowing solder and a clean smooth tip. They won't all be perfect, but as long as they're good joints... You'll have a good time. |
#22 (permalink) | |
Yep, you'll know it's good when they cool if they look shiny rather than dull. Just a real small point - on the power tube side of cathode bias amps, I like to put at least a little bit of space between the bias resistor and the bypass cap and/or other local e-caps, if there's room to do so. Not an absolute necessary thing, I just like to do it. That resistor will get hot. Looks good Herb! |
#23 (permalink) | |
#24 (permalink) | |
Herb I don't always play guitars , but when I do , I prefer tele's , stay twangy my friends |
#25 (permalink) | |
On the soldering , yea , I have noticed that when the joints cool down , also have noticed how the solder flows on a good joint , BTW , that WES51 is great :)
#26 (permalink) |
Got a little more done this evening , till my eyes got tired , board is mounted in chasis , jacks and switch are installed and connections soldered to board , tranny's are mounted . Dave was right , that brass plate makes a good template
#27 (permalink) |
Looks good.
Herb, you do not need that green ground wire on the input jacks. I used to isolate the inboard input jack and I have found that it is not necessary to do that. You have 3/8 inch star washers behind each input jack. Each jack makes ground to the chassis by its body. Technically, the green jumper is making a ground loop - so it is doing more harm than good by being connected. Snip it out of there and away you go. That's a 1 watt Allen Bradley 1.5K ohm resistor on the far right. Nice long leads on that sucker. Those 68K input grid resistors are also 1 watters. Exclusive offerings to TDPRI members upon request while supplies last. |
#28 (permalink) | |
#29 (permalink) |
That looks good, Herb! Nice shiny solder joints. Glad you like that Weller station. Not to be picky, but I usually make the leads from the input to the grid resistors as short as possible when not using shielded wire. Again, not a big deal, just cut those shorter if you have a tendency to pick up radio stations. Same with red wire going to the volume pot, it looks like you could shorten the path a bit. Sweet!
#30 (permalink) | |
#31 (permalink) |
Got the back boards made up and the cleats in the cab , sealed with polycrylic , just waiting on my tweed to come.
![]() Question for Dave or anybody else that knows on the PT , I am using the Weber layout sheet , the colors are different on the PT I have than whats shown on the Weber layout , the PT I got from Dave P-TF22772 Has 2 black wires , I am thinking one black to blue on a/c cord , the other black to fuse , also the red with yellow stripe goes to ground ? I am also thinking the two reds , two yellows and 2 greens go to the locations shown on the Weber layout , the OT I got from Dave has the same color wires as the Weber layout so I think they are OK to go where shown , just not positive on the PT .
#32 (permalink) |
The black wires are the primary, so you're correct on those, one to the fuse, one spliced to the blue (neutral) wire.
Yes, yellow/red is center tap of the two red wires, the high voltage winding, goes to ground. You can confirm this for yourself by setting your meter to K ohms and measuring between the two red wires. Say that measurement is 300 ohms. Now measure between red/yellow and one of the reds and it should be approx. half, 150 ohms. I usually solder the HT center tap to a ring terminal and fasten that down on one of the power transformer bolts as my main ground point, so the first two filter caps (-) and the power tube cathode/resistor (-) are also grounded there. You are correct on the rest, same as the Weber layout: Two greens, 6.3v filament winding. Two yellows, 5v rectifier filament winding. Cab's looking good!!! |
#33 (permalink) | |
#34 (permalink) |
All done soldering and wiring , not as neat as most of you fellas but I am pretty confident in all the solder joints , don't know if I'll try it before or after I get the cab covered with tweed but here's a few pics , hopefully there's no boo boos
#35 (permalink) |
Well , I might as well see if this works , so using the BYOC startup procedure , I installed the chasis in the cab , turned on the power switch , no tubes installed , nothing plugged into any of the jacks , plugged the power cord in while watching the pilot light , whada you know , the light came on , no sparks or explosions ,no smell , so far so good , unplugged the power cord , installed the 5y3 rectifier tube , light came on , tube started glowing after a minute , no smell , no sparks , unplugged the power cord , installed the preamp tube , plugged power back in , preamp tube started glowing after a minute , no sparks , no booms , unplugged power cord , installed speaker in baffle and plugged into speaker jack , installed power tube , made sure volume is at the lowest level , plugged power cord in , power tube starts to glow , all tubes glowing , no sparks or bad stuff happening , slowly turn up volume , it is making noise
#37 (permalink) |
Swap your OT leads to kill the squeal, I'm having trouble imagining the other static noise you're talking about but it could be a dodgy preamp tube.
The squeal is like a runaway train of positive feedback and swapping the primary leads on the OT should create the negative feedback that you need. Negative feedback -bad for children, but works pretty well in this design. ;) |
#38 (permalink) | |
#39 (permalink) | |
#40 (permalink) |
My 5F1 squealed too. On advice from Dave I reversed the leads to the output jack and it cured it. I think he said I could reverse the leads to the output jack OR the leads from the OT? Don't quote me on that... For me the output jack was easiest.
FWIW I get a static-y sound at anything over about 6 or 7 on the dial. I'm having too much fun with it to take it apart and try to fix that though! I figure when I pull it apart to Tolex the cabinet I'll address the noise. |
