| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
NHMAD!!!!
New home made amp day!
A few months ago I posted some questions about building an 18 watt Marshall with 6v6 tubes. I had this old Bell& Howell Filmosound amp from about 1947 that needed a rebuild. I completely gutted it and with some advice from savvy Forumites decided to build a Fender 6g3 lite. It is the bright channel ,basically without tremolo,which unfortunately, there wasn't any room for.The volume control has a pull function for negative feeback and there is a boost switch.The head slides in the back at a 45ish degree angle to help cooling and keep the cabinet as short as possible.I finished the guts of the amp a few months ago and got on to the cabinet.I wanted a 40's look for the amp so I went with the curved top section made from bent/laminated birch ply. The sides and bottom are finger jointed pine, by far the HARDEST cabinet I have built!This little guy flat out rocks!I am currently running a Celestion G12 H30 55hz, which seems to go with the somewhat Marshally crunch that it puts out. anyways , I hope you like it, I sure do! [IMG] [/IMG][IMG] [/IMG][IMG] [/IMG]
What the hell is he building in there? Last edited by G-log; May 23rd, 2012 at 02:02 PM. |
HI G-LOG Did you use the stock transformers from the filmosound amp? I just bought one from a local not knowing its potencial mods until I googled it .is it posible to build a fender 6g3 stock with a new chassis ,thanks by the way a beautiful amp!!!!!
"In moments of crisis, imagination is more important than knowledge" - Albert Einstein |
That looks very classy! Good work.
new music vid and band stuff: http://www.youtube.com/watch?v=Ysqfl...ature=youtu.be http://www.myspace.com/marshmallowcoast http://en.wikipedia.org/wiki/M_Coast |
