| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
Pentode/Triode mod
I have put this in my DR build and I was wondering what you guys think of it, is it worth it and are there any downsides to it? I found the volume drop was pretty disappointing for the amount of work installing it. Seeing there is already a Channel 2 which cuts the volume anyway, I'm thinking of pulling it out.
.....I love the sound of distortion in the morning!! |
I've done Merlin Belncowe's morph control in a couple of amps - definitely a worth-while thing (but you need a conveniently accessible space to put the pot)
He who dies with the most tubes... wins |
Here's my "6H3". Based on a 6G3 but with a switchable parallel/single stage in V1, and EF86 with the triode-pentode morph control as the tone stack recovery stage, and a whole tube for a 5G9 style bias-vary trem. For 6V6s its quite a loud amp when dimed
Think it was the output tube in question. So with the morph, does it put the tube in triode mode or reasonably close? I would like to do this but followed with a cathode follower and run triode in a Bassman circuit. Also how do you like the tone control?
#8 (permalink) | ||
I did come up with a schematic idea (attached) for trying the morph in an output stage but haven't implemented it yet. You could use a dual ganged pot, or for more tonal experimentation, two individual pots.
The tone control part is reasonably effective, there is quite a wide range and the mid-scoop/hump brings out the upper mids when dimed. But its completely different from a BF stack
I usually do layouts with a pencil and rubber so I don't have anything worth posting, but I'll take a few picks of the guts and stick them up in the weekend.
#10 (permalink) | |
And it's not like it is so different from a brown deluxe that you couldn't just tweak the existing layout. But, given how detailed and thoughtful your design was I had hopes that you'd have something super easy... Gut shots would be greatly appreciated, thanks! |
#11 (permalink) | |
My Epi BC30 (Bassman clone) has the pentode/triode switch (2x6L6GC). I don't use it. I added a master volume instead, and a couple other tricks. Just turn the volume down.
Interesting information for a future build...I can see someones face when they ask..What's that knob for?....It's a Morph control!! lol
