Old April 23rd, 2012, 10:16 AM   #1 (permalink)
cabinet dimensions
So, I've a friend with a TRRI and another with an SFTR...are cabinet dimensions the same for these amps? If I built two identical cabs, would I be able to use them for both amps, or are the chassis different?
Thanks, guys
marshman is offline   Reply With Quote
Old April 23rd, 2012, 10:29 AM   #2 (permalink)
muchxs's Avatar
The chassis are dimensionally the same but there are slight differences.
The TRRI uses the '60s style cabinet with the removable baffle. '70s SF has a fixed baffle. Pretty sure the rear flange on the reissue chassis is bent out instead of in like the originals. I mostly see / work on vintage. There are a couple screws through the flange from the underside.
Either one will fit.
