| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
![]() Friend of Leo's
Thanks. The blue is even more vivid than seen here. Orange and Blue are Florida Gator colors. That's why I used the Orange Drop Caps.
The 25uF bypass cap will be turned on or off by the The NFB switch. |
Are you guys saying, you could possibly install a pot for variable NFB resistance? Just pull the resistor and wire the leads to a pot instead? Is this similar to the presence knob on some amps? Thx.
'68 SFVC, '64 Bandmaster Head & Cab, Boothill 5F1 Clone, Boothill 5F2A Clone, Ceriatone 18W TMB Head with Marshall 1960A JCM900 Cab |
#9 (permalink) | |
![]() Would work the same way for shorting out the bottom leg of NFB on the driver stage of a cathodyne inverter (like a princeton reverb)
He who dies with the most tubes... wins |
Kinda. A presence control is typically just a variable frequency pot in an NFB circuit, that 'boosts' treble frequencies (by cutting the gain of selected mid-treble frequencies fed-back through the NFB loop). (But you can have this kind of control in local feedback loops). If you took away the pot's bypass cap, you would have just a plain old NFB blend/gain control.
#11 (permalink) | |
It's the Hackworth / Muchxs Champ. "Muchworth" sounds arrogant. I like "Much Hack" better. Y'all are overthinking the NFB thing. That's the "danger" of simple little amps. Make everything adjustable and switchable, it isn't a simple little amp anymore. There is a short list of rules in a stoic engineering philosophy. First rule is "Parts left out" which means leave out anything you can omit. Find a killer tone and hardwire it. Somewhere on the list is "Anything adjustable can be mis-adjusted". That means there may be settings that are cool by themselves that sound like crap in conjunction with other settings. Next in our slide down a slippery slope is a tone control. Then a full tone stack. Then a master volume... |
.....change the pre-am tubes etc. etc......that's s very true muchxs. I've been playing around with hackworths GA-5, while it's interesting to hear what happens when you do this and that. Ultimately it's just a matter of how much volume and clean/overdrive levels you want at the time and being able to dial it in, that is what I find is cool
.....I love the sound of distortion in the morning!! |
#14 (permalink) | |
Aww heck, I can't help myself, got a new idea on switching around a classic preamp that I need to post. Will end up with more switches than resistors yet. |
