Old April 18th, 2012, 02:00 PM   #1 (permalink)
First Amp Build (a little off topic but looking for info)
I have been wanting to build an amp from scratch since loving the Bill M mods I did to my Blues Jr. My better half brought up the fact that I do not really need another guitar amp and I may just agree with her. But my better half also brought up a project idea that this group may know something about.
The lady has requested a proper tube amp for our record player and other home music needs. Has anyone in this group ever built one? Are there any kits that you all may suggest?
Thanks for the help and letting me get off topic a little.
Bob A is offline   Reply With Quote
Old April 18th, 2012, 06:08 PM   #2 (permalink)
printer2's Avatar
http://www.diyaudio.com/forums/tubes-valves/
printer2 is online now   Reply With Quote
Old April 18th, 2012, 06:51 PM   #3 (permalink)
Most of my background is in HiFi, MI amps are a relatively new thing for me.
How much power do you need? What kind of equalisation do you need? Do you want a kit or do you want to source the parts yourself?
celeste is offline   Reply With Quote
Old April 20th, 2012, 03:26 PM   #4 (permalink)
Bob, you oughta give that lady a hug for giving you such a job....your ears will appreciate when you get it done....and more importantly, she will let you build a gutiar amp after you get those tube harmonics pushing out her favorite recordings.
Old April 20th, 2012, 06:11 PM   #5 (permalink)
If you look at the old victor console stereos you will see they are not very "powerful" but plenty loud; I got a nice 1962 Victor from a guy who couldn't afford to have it fixed. I retubed & recapped it. Everything works! and it sounds real nice.
It has stereo EL84 single ended channels, real simple, less than 10w each. Each channel drives a 12" and 2-3" speakers. It is plenty loud for a room, but if I were to build one I would go P-P on each channel. Other than that it should be pretty straightforward, depending on your experience level.
firemedic is offline   Reply With Quote
Old April 24th, 2012, 07:09 PM   #6 (permalink)
Will do!
So I didnt mean to post a thread and then get out of the discusstion but hey life happens.
The power would be standard US 110 and as far as speakers i am still trying to research that.
Thanks to printer for the forum link I will start there but will most likely be getting a kit from a supplier they suggest.
Old April 24th, 2012, 07:24 PM   #7 (permalink)
Originally Posted by Bob A View Post
Will do!
I meant output power. Do you have a preference of single ended or push-pull?
This is a nice simple well documented stereo SE using 6V6's and 6SL7's
http://ax84.com/harmless/harmless_r0.pdf
Old April 24th, 2012, 08:00 PM   #8 (permalink)
Tube HiFi is great stuff.
As long as your OCD is properly controlled. Otherwise there be dragons...
Keyser Soze is offline   Reply With Quote
Old April 24th, 2012, 08:11 PM   #9 (permalink)
You might check Dynaco clone kits too, ST35, SCA35. Popular amps, I'm sure there are many kits once you start looking.
Not to steer you away, but the DIY audio site is a great place to hang and search. Be a member, and don't forget about us!
FenderLover is offline   Reply With Quote
Old April 24th, 2012, 08:16 PM   #10 (permalink)
macaroonie's Avatar
My background is Hi Fi also but I am not tube savvy , however as Celeste will agree the rules are very different compared to guitar amp use. In general you want a very linear power supply in the ampwhich means plenty of capacitor smoothing. Also go big on your transformers. Its all about keeping the amp linear as best you can. Distortion is not what you are aiming for at all. Once you have that in your mind you are on your way.
Good luck M
macaroonie is online now   Reply With Quote
Old April 24th, 2012, 08:32 PM   #11 (permalink)
^^+1 on that. I have well over 10K into my system, and only one volume knob, the way God intended. (actually, it's a balanced step attenuator, but I digress)
Old April 25th, 2012, 06:16 PM   #12 (permalink)
Also, there currently is no 12 step program for audiophiles.
Probably should be one...
Old April 25th, 2012, 09:53 PM   #13 (permalink)
Lilly is working on a nasal spray that simulates solder smoke, I tried it and it's nothing the real thing, but it does help with the cravings.
boredguy6060 is offline   Reply With Quote
