| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
Hello! This is for my fellow newbie brothers and sisters(?) (Wish there were more :))
One advantage for working for a tech is I've seen dozens of old and new amps over the past couple months. Here's some tube pin pics that may help: Probably everyone knows on the 12ax7s Fender bent the heaters 4&5 together (9 is on its own...lonely). Also, you may have a design that calls for linking your cathodes together (3&eight). You can just bend them in! You can remove the center piece of metal from the socket, if it has one. Tidy!
new music vid and band stuff: http://www.youtube.com/watch?v=Ysqfl...ature=youtu.be http://www.myspace.com/marshmallowcoast http://en.wikipedia.org/wiki/M_Coast |
![]() Friend of Leo's
Good Tip, Andy.
Be aware that if there be a metal piece in the middle... ...that middle piece secures the two sandwiched halves of a ceramic tube socket. If it is removed... and you didn't fold over two outside pins... ...the assembly will come apart. |
Easy heaters.
Also, a resounding yes re: what Hackworth said. I ruined a socket with my kit. I didn't realize on some 9 pins it holds two halves together. Also, I was hoping others might add fun stuff here :)
#7 (permalink) | |
charisjapan * Teleology = Intelligent Design |
Lol Charis, I'm starting to wonder when you sleep!!!! What time is it there?!?!
I know, I kind of wish I were using solid wire for the heaters, it's a tight squeeze on the 9 pins. I'm about to blow some minds (not really) with a few wiring deviations on the heaters, output tubes, and pt. Will update the build thread soon.
#9 (permalink) | ||||
