Old April 3rd, 2012, 11:30 PM   #1 (permalink)
wallis222's Avatar
Removing Epiphone Logo From Valve Junior Cabinet
As the title says....
The Epi logo doesn't go with the logo on the amp head that I've got it paired with. Has anyone removed one of these before? There is a guy online who removed the logo from a Valve JR. Head - He removed the front panel and then you can pop it off from the inside (see link below). I guess the only other option is to pry it off... Has anyone done this successfully?
http://www.billrushing.org/20060711_...junior_pt2.htm
Thanks.
-"If you don't have a toothbrush, and you don't have a Telecaster you're in trouble!" Jim Weider
-They're all partscasters." Me
wallis222 is offline   Reply With Quote
Old April 4th, 2012, 07:25 AM   #2 (permalink)
I would carefully sand it away starting with 800-1200 paper and a HARD block, no bigger then 1"x2". Treat it like a big paint run you need to level.
celeste is offline   Reply With Quote
Old April 4th, 2012, 08:06 AM   #3 (permalink)
teleamp's Avatar
If it is the same as the VJ combos, just take a putty knife and slide under and pry it up and off, it's just pressed on.
teleamp is offline   Reply With Quote
Old April 4th, 2012, 08:59 AM   #4 (permalink)
wallis222's Avatar
Great.
Old April 4th, 2012, 01:45 PM   #5 (permalink)
It's a little weird to click on a thread and find a link to my own website. Well, hope it was helpful.
The putty knife trick ought to work, just be really careful or you'll rip the tolex.
Arbiter is offline   Reply With Quote
Old April 4th, 2012, 02:48 PM   #6 (permalink)
wallis222's Avatar
That would be weird. Your little valve junior looks great by the way. The amp I am running with this cab is not an Epi, but it matches pretty good.
Old April 4th, 2012, 03:17 PM   #7 (permalink)
Thanks, I like how it came out looking. Wouldn't do it again, though, a painted amp gets beat up real fast. Probably going to tolex it this year.
Kewl looking amp you've got there. What is it?
Old April 6th, 2012, 12:28 PM   #8 (permalink)
Modern Saint's Avatar
I popped mine out by disassembly of the cabinet. Right now it being rebuilt.
~Go For What You Know!~
~There are no bad notes, just bad resolutions! - RLH~
~Make Everyday Your Masterpiece. - John Wooden~
Modern Saint is offline   Reply With Quote
