| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
Fixed bias and standby switches
On my next build I was planning to not have a standby switch but I have read different things about fixed bias.
I have read that without the negative bias already running before the power tube HT is switched on, the tubes can red plate before the bias gets to its proper level. This seems to say to me that a standby switch is necessary with fixed bias, and that the bias system needs to be included in the standby system. I will use one if it is necessary but I would rather not. What are people's thoughts on this? |
If you have SS diodes in both then if one has a greater time constant than the other it will charge up sooner. If you have a SS diode feeding your bias circuit and you have a tube rectifier I would think the bias might charge up before the plate supply. Even if the bias is not charged up to its full voltage it may be partly charged limiting the dissipation of the output tubes. Mind you I have not worked with a fixed bias amp yet, just theorizing.
Having -DC bias voltage on yer power tube's grid, before the plate gets its B+ and the tube is flowing current, will not harm the tube.
Flowing current with no bias voltage certainly will. i.e., leave the bias supply independent of the standby switch. |
To each his own, but I love standby switches! They are simple to install and have great advantages:
1-Allows the heaters to warm up your tubes before hitting it with high voltage DC that saves tube life. 2-Allows you to mute your amp while you take a break with the heaters and bias still running so you have instant sound when you come off break. 3-I don't know, there should be a third good reason??? An extra switch makes your amp look more expensive and technical!!!;>}
On the Right Track now Baby<>< |
#8 (permalink) | |||
I NEVER set my amp to Standby during a break, because of the aforementionned problems with keeping tubes hot with no current going through, also because even though the filaments are hot other components are still heat-cycling every time you switch to standby and back so you can actually lower life expentancy. Once it's on, I keep it on for the full night. Quote:
There is a theory that Leo started putting a Standby switch because some rectifier tubes created a voltage spike when turned on which would go above the power cap rating. Think about it: do you really think your grand father let his radio on Standby for 2 minutes before turning it on? I don't think so
Why build it if you can buy it? Make it special! |
#9 (permalink) | |
I now put a 'mute' switch in the amps. Routes the signal to ground just before the PI. steven
Bow ties are cool. Fezzes are cool. |
#10 (permalink) | |
Ha ha good call, however I like things as simple as possible, I really liked Fezz's amp he showed the other day with one knob, and it was a tone knob. One day I will build an amp with no knobs at all, just use the ones on your guitar, just for a laugh more than anything.
#13 (permalink) | |
RE: Gibson and standby switches....I am going to have to study that one. Interesting. |
#14 (permalink) |
Long ago, all our domestic electronics had valves.
And not one of them had a standby switch. Hartley Peavey writes a paper on the evils of standby switches http://peavey.com/support/technotes/.../chapter_6.pdf and then builds amps with standby switches because his customers want them... If your amp has a valve rectifier then a standby switch is about as much use as a chocolate teapot. With a solid state rectifier it is merely a fashion accessory.
#15 (permalink) | |
Gibson Duo Medalist Cool different way Gibson GA100 Gibson GA300RVT Gibson GA30RV |
#16 (permalink) | |
As for being a fashion accessory, I believe the technical term is FalseFi. Controls of dubious use, or not even connected, added for the sole purposeof impressing people |
#18 (permalink) |
![]() Friend of Leo's
Peavey Article is very good.
Peavey does not malign the use of a standby switch for initial tube heating on start up. Fast-Heating, Directly-heated rectifier tubes (such as the common 5Y3) combined with indirectly heated preamp tubes (12AX7, etc) and power tubes (6V6, 6L6, etc) benefit from a standby switch or an inrush current limiter or both. Peavey says that a standby switch should not be used on beer breaks longer than 15 to 20 minutes in order to avoid cathode poisoning. IIRC, Peavey stated that it is preferable to leave the amp fully powered-up during breaks. Also that the 5AR4 Rectifier (3 amps current draw) is preferrable - due to its indirectly heated cathode - wherever it can be used instead of the 5Y3 (2 amps). Be mindful of current draw. |
#19 (permalink) |
I am new at this so help me out. I use a standby switch so that I can mute the amp when I switch guitars. Since I only play at home and have a number of guitars I often change a number of times when practicing. Is this a good enough reason for a standby switch? Should I be using a different wiring scheme for this such as a mute switch as described above? If so, how do you wire it?
Thanks, Tom |
