Old February 25th, 2012, 07:25 PM   #41 (permalink)
mgdesigns's Avatar
Make one out of scrap steel. Seems like it's a pretty easy part; the bassman cap cover is not a stamped box, and has open corners.
Old February 25th, 2012, 07:26 PM   #42 (permalink)
I think I will. So, will any metal work? You said steel. Would aluminum work? I'll look for a sheet of something strong but not too hard to bend or cut.
Pretty easy thing to make either way.
Is this cover meant for shielding, or just so you can't accidentally reach around and touch a live cap? I'm guessing it's plenty shielded being on the outside of the chassis.
JBennett is offline   Reply With Quote
Old February 27th, 2012, 04:57 PM   #43 (permalink)
Okay... well I walked to home depot on my lunch break. Bought a pair of snips and a sheet of zinc. measured, clipped, and folded it (using my desk drawer at the office) in 10 minutes.
Cost less than any available "doghouse" and I get to keep the snips! (and the zinc, which is supposed to be good for colds, right?)
Thanks for the nudge MGD.
Old February 27th, 2012, 06:22 PM   #44 (permalink)
hackworth1's Avatar
Woof, Woof! Looks as good as any doghouse I've been in.
5F1 & 5E3 Kits, See Vendor Forum Specials & www.BootHillAmps.com
Old March 1st, 2012, 12:15 PM   #45 (permalink)
So, I'm getting close to taking out the current guts. A few questions...
Seems to me that by looking at the schematic for the reissue and the original unit, the choke has two black wires. Does it matter which side the choke wires come from? Or is it not an issue which way it is fed from the rectifier board?
Same question for the heaters. Are both green wires from the transformer interchangeable? Can I send either one to the tip of the pilot and then just send that wire to the 2/3-4/3-4 and the other to the 7/9/9 pins?
Everything else is pretty clear, but the transformer wires are a bit confusing due to the duplicate colors. I'll be clearly marking the current connections with labels once I clip the plug ends and I'll send those to the same connections as on the RI.
For example CP-8 from the PT goes to the AC switch and CP-3 goes to the fuse. (these are the two black wires from the PT)
BUT!!!!
CP-11 and CP-12 (the two RED wires from the PT) seem to be interchangeable?
Old March 3rd, 2012, 10:31 PM   #46 (permalink)
Old March 3rd, 2012, 11:09 PM   #47 (permalink)
andyfromdenver's Avatar
I can feel the humidity increasing :). Gonna get my umbrella!
andyfromdenver is offline   Reply With Quote
Old March 4th, 2012, 07:36 AM   #48 (permalink)
hackworth1's Avatar
JBennett,
All your suppositions are correct. Proceed at will.
Old March 4th, 2012, 09:12 AM   #49 (permalink)
Thanks Hackworth. I've gotten some more wiring done this morning. The power supply is all wired up to the fuse/light/switch/rectifier. Just waiting on a package from Watts with some jacks and wire and I'll be ready to wrap it up.
Old March 4th, 2012, 09:56 AM   #50 (permalink)
Old March 4th, 2012, 10:54 AM   #51 (permalink)
You're in the doghouse now...
Old March 4th, 2012, 11:04 AM   #52 (permalink)
TheRumRunner's Avatar
Really enjoying this build out - thanks for taking the time to share.
DW
A Rhum drinker with a Guitar fetish
TheRumRunner is offline   Reply With Quote
Old March 4th, 2012, 12:20 PM   #53 (permalink)
Thanks for watching. I hope to have it all finished by this time next week. (assuming my package gets here)
One thing I don't have that is on the originals is a brass plate under the pots... like in this photo of a vintage unit:
Do I need one? If I need one, could I cut it out of the same zinc sheet I made my doghouse from?
Old March 6th, 2012, 07:53 AM   #54 (permalink)
Package is still on its way. Cleaned up power supply wiring a bit and soldered in the two 100 ohm resistors on my octal socket. And soldered up the OT leads to the RCA out. And crimped a nut mount collar on my rectifier ground.
Outlet works, and the PT fires up a-okay. Jewel lamp glows, just above 130vdc before the diodes on the rectifier and just over 250vdc after they pass through the rectifier. 8ish vac on the greens. 130vac on the primaries. Something like that. Once it's all wired up I'll photograph all the readings.
Jacks have resistors and are installed.
Old March 6th, 2012, 11:51 PM   #55 (permalink)
Wired up the heaters. They are pretty out of the way of everything this way. And, they work! I even dropped in some tubes and they warmed up to a nice, healthy orange glow.
Old March 7th, 2012, 09:20 PM   #56 (permalink)
New AC wiring... and 1/2 watters that I found at Leeds Audio... crusty bastards.
Old March 8th, 2012, 04:10 PM   #57 (permalink)
Final package delivered. I should have this thing finished by morning light...
Old March 8th, 2012, 08:34 PM   #58 (permalink)
false alarm, wrong package. Tomorrow night I guess...
Old March 8th, 2012, 08:36 PM   #59 (permalink)
Awww!! I hate it!
Old March 9th, 2012, 10:14 AM   #60 (permalink)
Arrival! Tonight I'll try to get it all wired up and fired up.
Here is my assistant.
