Old January 31st, 2012, 08:38 PM   #1 (permalink)
Jcn3's Avatar
weber 5e3 head pics
i finished a weber 5e3 kit a month or so ago and am really loving it. the sound is fantastic -- huge yet detailed, great chime if wanted, great dirt if wanted. i paired it with a cannabis rex in a cab built based on the ax84 plans. this amp made my pro junior sound so anemic that i sold it.
i'm really pleased with the quality of the kit (i didn't get tubes from weber) -- i'm sure it's going to be a great amp for a long time.
i was asked by another member for some pics so you could see the back open. since there aren't many heads out there, i thought i'd share with everyone.
the back doesn't seem ideal -- seems like there should be some way for heat to escape from the top -- but i haven't had any problems (although i am a light user -- the amp is never on for more than a hour at a time). i may make another back with a matching cutout on the top.
enjoy!
Name:	027 - Copy.jpg
ID:	111685   Click image for larger version
Name:	029 - Copy.jpg
ID:	111686   Click image for larger version
Name:	030 - Copy.jpg
Jcn3 is offline   Reply With Quote
Old January 31st, 2012, 09:03 PM   #2 (permalink)
keithb7's Avatar
Congrats on a great looking amp. You've made a 1955 circuit into a modern looking amp with that cab. Is there a single Cannis Rex 12" 8 ohm speaker in the cab?
'68 SFVC, '64 Bandmaster Head & Cab, Boothill 5F1 Clone, Boothill 5F2A Clone, Ceriatone 18W TMB Head with Marshall 1960A JCM900 Cab
keithb7 is online now   Reply With Quote
Old January 31st, 2012, 09:24 PM   #3 (permalink)
Way cool!
Dim lights, thick smoke, and loud, loud music.
It's the only kind of life you'll ever understand.
You'll never make a wife to a home lovin' man.
Ricky D. is offline   Reply With Quote
Old January 31st, 2012, 10:09 PM   #4 (permalink)
hackworth1's Avatar
Nice. That would be cooler with a vent in the top. Air would flow from the back opening through the top vent. In any case, you could put some foil under the tubes and heat your lunch. Just Kidding. It is a very nice looking rig. Pretty work.
5F1 & 5E3 Kits, See Vendor Forum Specials & www.BootHillAmps.com
Old January 31st, 2012, 10:21 PM   #5 (permalink)
andyfromdenver's Avatar
Looks super clean. Good work on tolexing the corners.
You can still make a tweed deluxe cab too and just drop it in :)
andyfromdenver is online now   Reply With Quote
Old January 31st, 2012, 10:28 PM   #6 (permalink)
Are you wondering why you made it so tall? No biggie, it looks like nice workmanship. I'd be so lucky to pull that off.
I like the Marshall-mount for a tweed chassis.
FenderLover is offline   Reply With Quote
Old February 1st, 2012, 12:08 AM   #7 (permalink)
Thanks much, I needed that!! What a clean head inside and out. I too like the Marshall style mount, gives easy access and an un-tweed look. I appreciate the open back shot!! Would you mind telling me what the dimensions are? Have you had any issues with heat from the tubes?
sjturbo is offline   Reply With Quote
Old February 1st, 2012, 08:03 AM   #8 (permalink)
Jcn3's Avatar
Originally Posted by keithb7 View Post
. . . You've made a 1955 circuit into a modern looking amp with that cab. Is there a single Cannis Rex 12" 8 ohm speaker in the cab?
yeah, i know -- it was intentional. i do like black tolex with the fender grille cloth!
after having tolexed with black, i can't possibly image trying to align tweed!
Old February 1st, 2012, 08:14 AM   #9 (permalink)
Jcn3's Avatar
are you talking about the cabinet for the amp? it actually came with the kit from weber, so you get what you get . . . my guess is that they were trying to keep things simple and have a head cab that would work for multiple kits.
it actually look very nice with the speaker cab, i think.
Name:	002 - Copy.jpg
Old February 1st, 2012, 08:19 AM   #10 (permalink)
Jcn3's Avatar
Originally Posted by sjturbo View Post
. . . Would you mind telling me what the dimensions are? Have you had any issues with heat from the tubes?
the dimensions are 20"w x 9"h x 9"d. i haven't had issues with heat from the tubes, but remember that i'm just a hack and don't gig with it. i can tell you that the top of the opening for the tubes in the back gets warm (not hot) and the extra glue on the inside seems to get sticky.
Old February 1st, 2012, 08:21 AM   #11 (permalink)
Jcn3's Avatar
Originally Posted by andyfromdenver View Post
. . . You can still make a tweed deluxe cab too and just drop it in :)
after the amount of time it took me to tolex the speaker cab, i'm not sure its worth my while to make these things. a lot of it had to do with the glue i used -- it took way too long to cure, so the apply the glue, wait, wait, wait, apply the tolex drove me crazy.
Old February 1st, 2012, 08:23 AM   #12 (permalink)
Jcn3's Avatar
. . . Is there a single Cannis Rex 12" 8 ohm speaker in the cab?
yes, exactly right. the speaker sounds really nice, but the bottom end is almost too much. of course, i do have it in a corner and use it in a basement room . . . i'm sure someone who gigs with it would appreciate the bass in a larger room.
Old February 1st, 2012, 09:31 AM   #13 (permalink)
I, too, built a AX84 cab for my 5E3(ish) build. The AX84 cab is super bassy if you keep the panels on the back. Try pulling one of them off. I used a Jensen Jet Falcon in mine.
Commodore 64 is offline   Reply With Quote
Old February 1st, 2012, 02:21 PM   #14 (permalink)
hackworth1's Avatar
Changing coupling capacitors from .10uF to .022uF cuts the boominess in a big way. especially the first two caps.
It is easy to swap out those first two caps to try it.
Old July 15th, 2012, 10:44 AM   #15 (permalink)
DC Music's Avatar
Sorry to revive an old thread, but when you're placing an amp in a head cab like that, is it safe practice to have the tubes lying horizontally? I've only ever seen tubes sitting vertically, either hanging down or sitting on top of the chassis.
DC Music is offline   Reply With Quote
Old July 15th, 2012, 11:02 AM   #16 (permalink)
SFenn's Avatar
With retainers on all the tubes like he's doing here, I dont think it's a problem.
SFenn is offline   Reply With Quote
Old July 15th, 2012, 01:11 PM   #17 (permalink)
hackworth1's Avatar
I've read that some tubes require a particular orientation, but the tubes in a 5E3 can operate at any orientation.
Old July 15th, 2012, 05:54 PM   #18 (permalink)
DC Music's Avatar
How about 5F6-A?
Old July 15th, 2012, 06:55 PM   #19 (permalink)
hackworth1's Avatar
Ditto 5F6A.
The 6L6 can lay out horizontal also.
