Old January 18th, 2012, 07:52 PM   #1 (permalink)
guycalleddave's Avatar
Trinity 5e3 Build. Please Critique
So I populated the board finally. Here are some shots.
Please let me know if you see anything I should fix before I continue on.
Your comments are very much appreciated.
Thanks,
Dave
Name:	Screen shot 2012-01-18 at 7.48.03 PM.jpg
ID:	109706   Click image for larger version
Name:	Screen shot 2012-01-18 at 7.48.22 PM.jpg
ID:	109707   Click image for larger version
Name:	Screen shot 2012-01-18 at 7.48.35 PM.jpg
Name:	Screen shot 2012-01-18 at 7.48.49 PM.jpg
ID:	109709   Click image for larger version
Name:	Screen shot 2012-01-18 at 7.49.03 PM.jpg
guycalleddave is offline   Reply With Quote
Old January 18th, 2012, 07:56 PM   #2 (permalink)
more pics
here you are.
Name:	Screen shot 2012-01-18 at 7.49.13 PM.jpg
ID:	109711   Click image for larger version
Name:	Screen shot 2012-01-18 at 7.49.22 PM.jpg
ID:	109712   Click image for larger version
Name:	Screen shot 2012-01-18 at 7.49.33 PM.jpg
Name:	Screen shot 2012-01-18 at 7.49.44 PM.jpg
Old January 18th, 2012, 08:51 PM   #3 (permalink)
Looks good to me! ... it's tough to keep things in place with so many leads under the board.
rock_mumbles is offline   Reply With Quote
Old January 18th, 2012, 10:57 PM   #4 (permalink)
printer2's Avatar
The lighting could be better.
printer2 is online now   Reply With Quote
Old January 19th, 2012, 09:08 AM   #5 (permalink)
lol, awesome. i feel better now.
Old January 19th, 2012, 09:42 AM   #6 (permalink)
Dave, when I built my Mission kit, I used my layout drawing and a highlighter to check the board. Verify a node has the proper components in place and a good solder joint, highlight the node on the drawing, repeat.
Dim lights, thick smoke, and loud, loud music.
It's the only kind of life you'll ever understand.
You'll never make a wife to a home lovin' man.
Ricky D. is offline   Reply With Quote
Old January 19th, 2012, 10:08 AM   #7 (permalink)
keithb7's Avatar
I notice some of your capacitors and resistor leads have shielding around them. I have not seen this before. Nor did my Trinity 5E3 kit mention it. Does this help with noise interference? Looks great to me. Move on to next step!
'68 SFVC, '64 Bandmaster Head & Cab, Boothill 5F1 Clone, Boothill 5F2A Clone, Ceriatone 18W TMB Head with Marshall 1960A JCM900 Cab
keithb7 is offline   Reply With Quote
Old January 19th, 2012, 02:22 PM   #8 (permalink)
Honestly, I have no idea if it helps. Figured it couldn't hurt though.
I just finished the input jack wiring this morning.
Probably will so some more tomorrow before work as well.
Old January 19th, 2012, 08:26 PM   #9 (permalink)
hackworth1's Avatar
I take it that Trinity instructs you to install the wires underneath the board.
5F1 & 5E3 Kits, See Vendor Forum Specials & www.BootHillAmps.com
Old January 19th, 2012, 08:46 PM   #10 (permalink)
Yes that is how stephen recommends doing it.
Old January 22nd, 2012, 09:35 AM   #11 (permalink)
Is it me or is the output tube bypass cap reversed?
EdMax is offline   Reply With Quote
Old January 22nd, 2012, 10:58 AM   #12 (permalink)
hackworth1's Avatar
Good eyes, Edmax.
GuycalledDave, you must mind the polarity on those electrolytic capacitors. The metal end of the cap goes to ground. Desolder that cap and flip it end for end.
Old January 22nd, 2012, 11:02 AM   #13 (permalink)
Originally Posted by hackworth1 View Post
Good eyes, Edmax.
Its those little things that always get ya
Old January 22nd, 2012, 11:23 AM   #14 (permalink)
hackworth1's Avatar
Those little buggers will explode if they're backward when powered up.
Old January 22nd, 2012, 03:12 PM   #15 (permalink)
I'm pretty sure they are all the same way, I'm not at my house right now but I' m pretty sure they are all the same way
Old January 22nd, 2012, 03:38 PM   #16 (permalink)
Telenut62's Avatar
Looks ok to me the crimped ends pointing to the tube sockets, negatives to ground
.....I love the sound of distortion in the morning!!
Telenut62 is offline   Reply With Quote
Old January 22nd, 2012, 04:19 PM   #17 (permalink)
Edmax is correct the bias cap is backwards
Viejo is offline   Reply With Quote
Old January 22nd, 2012, 04:30 PM   #18 (permalink)
Telenut62's Avatar
Ah yes I see it now
Old January 23rd, 2012, 11:35 AM   #19 (permalink)
wire seems a bit heavy, what guage are you using?
Cruisin Home is offline   Reply With Quote
Old January 23rd, 2012, 12:45 PM   #20 (permalink)
20 gauge I believe
