| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
5E3 New Build with Mods Questions
I'm thinking about either a kit 5E3 or sourcing the parts myself. I'd like following mods:
1. Penthode/Triode Switch (to go from full-power to half-power): Yes, I know many people here do NOT like this. But I do. 2. Mid knob: I believe there's a fixed resistor (6.5 k?) that I just replace with a 25k(?) pot. 3. Effects Loop? 4. NFB switch? (to either turn it on/off or to change values) 5. ??? I'd really like a schematic/wiring for mods #1 and #2 above, if anyone's done it. I have seen a small diagram for the Penthode/Triode switch but not in context of 5E3. Would anyone be able to get the 5E3 schematic modified with a penthode/triode switch?
"Never commit yourself to a cheese without having first examined it." --T.S. Eliot. |
2. Mid knob: I believe there's a fixed resistor (6.5 k?) that I just replace with a 25k(?) pot You're thinking about a Blackface tone circuit here, I believe. The 5e3 is a different-much simpler-circuit. |
Oh, my bad. 5E3 is just a volume and tone, isn't it? I was thinking Treble/Mid/Bass in addition to Volume. Great, we can strike out the mod #2 from the list!
Easy enough to do. You need a DPDT switch, the center contacts go to each screen, one outer contact on each side goes to the plate of each respective tube, the other outer contacts go to the screen PS node 2. Mid knob: I believe there's a fixed resistor (6.5 k?) that I just replace with a 25k(?) pot. Very different animal 3. Effects Loop? Got to know what you want from it to suggest a topology. this just might be heresy. 4. NFB switch? (to either turn it on/off or to change values) There is no NFB in a 5E3, that is part of its charm, but if you really want to go that way you are going to have to copy someone else that has done it successfully because NFB is a pain to get right. 5. ??? Low/high voltage? use the tube for the low voltage, and parallel it with SS diodes and a switch to turn them on and off. It would get you more power and more headroom |
Be scientific. Build it stock first. Then you have a baseline to work from.
You're building the wrong amp, anyway. It sounds like you want a Brown Note D' Lite. It has all the features you want in it already. |
Thanks, guys!
@celeste, What spec DPDT switch, voltage/current? @muchxs, I never even heard of the Brown Note D'Lite until you mentioned it. You learn something new everyday. I love this community.
Brown Note D'Lite $2185
http://store.bnamp.com/dlite22.html I don't know about you but I'd rather pass. It's too expensive. I'm going to be scientific about it and build a simple 5E3 circuit amp with my own mods.
See now you have the usual issue here as with standby switches. It is real hard to find a switch that is rated for the voltage, and when you do, they are expensive. If you feel safe with a 250v rated switch like a standby switch usually is, then there is your voltage rating. Current is less then 1/4 amp
#9 (permalink) | ||
Know what Dumble is doin' these days? He's building 5E3s! Quote:
I've got some gnarly 6A @ 250V bat switches if you're feelin'a little insecure. Last edited by muchxs; October 21st, 2011 at 09:01 PM. |
#10 (permalink) | |
#11 (permalink) | |
Start flippin'... |
#12 (permalink) | |
Negative feedback, see the 5F10 Harvard. Use a SPDT switch with the center terminal at the tube cathode, one position then goes to the bypass capacitor used in the 5E3, the other position disconnects the capacitor and connects to the feedback resistor as in the Harvard. Use a pot to experiment how much resistance and level of NFB works well.
#14 (permalink) |
You could use the 5E3 as a starter kit: the Ground switch could be the Pentode/Triode switch; if you don't need 4 inputs, two of them, its triode and volume could be the FX loop. With those mods, the silk screen on the chassis wouldn't make sense, so drill a custom chassis and roll your own. The Brown Note route sure sounds appealing if you're not into design work.
