| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
![]() Friend of Leo's
Champ 600 to 5F1 Conversion
![]() By boothillamps at 2011-10-17 Which Jacks Would You rather Rely On? ![]() By boothillamps at 2011-10-17 Here's the original Champion 600. One of the first Tube Guitar Amps to be Manufactured In China. ![]() By boothillamps at 2011-10-17 Here's the Champ 5F1 Circuit developed over 5 decades ago. Modern high quality Components on a turret board which easily fits in the Champion 600 chassis. Buy one of my 5F1 kits and convert your own late model 600 to the original Heavy Duty Champ 5F1 Circuitry. Last edited by hackworth1; October 17th, 2011 at 09:10 PM. |
In this build, I'm installing a Weber W022772 Power Transformer and a Tube Rectifier. The Power Tube Socket becomes the Rectifier Tube Socket. A new hole must be punched out for the Power Tube.
For simpler and cheaper kit projects, a Full Wave Diode Rectifier should be utilized. That way, the existing PT can remain in place. This amp will be a 5F1 Clone with old-fashioned (tee hee!) tube rectification. There are various schools of thought on this aspect. A Diode Rectifier cicuit is lightweight, uses less energy, is easy to make, cheaper, and can use the existing light weight PT. A tube rectifier creates more light and heat. Looks cool. |
![]() By boothillamps at 2011-10-18 Chassis punch ![]() By boothillamps at 2011-10-18 ![]() By boothillamps at 2011-10-18 Makes nice hole. ![]() By boothillamps at 2011-10-18 Original Output Jack Location is a good place for fuse holder. ![]() By boothillamps at 2011-10-18 ![]() By boothillamps at 2011-10-18 |
![]() By boothillamps at 2011-10-19 ![]() By boothillamps at 2011-10-19 ![]() By boothillamps at 2011-10-19 ![]() By boothillamps at 2011-10-19 ![]() By boothillamps at 2011-10-19 ![]() By boothillamps at 2011-10-19 ![]() By boothillamps at 2011-10-19 She's fired up and sounding great. |
If you could provide some pictures and describe your project here or elsewhere on this forum... help will be forthcoming. Let us see waht you got and waht you intend to do.
Like Hannibal said, Quid Pro Quo. |
Right now I have the amp sitting in factory condition, and I have a 5f1 ptp board. I want convert over to a 5f1 configuration but using a ss rectification. The problem I am having there are not schematics I can find to do this. So I don't know if I should just pull the factory board and make the rectifier circuit or tap the factory board.
#14 (permalink) |
Make a full wave diode rectifier with four 4007 diodes. Check this build. Scroll way down til you see it. Then scroll farther til you see it in the chassis. There are four connections.
Two for the reds. One ground, one output to your board. http://www.tdpri.com/forum/shock-bro...erb-build.html |
#17 (permalink) | |
Champion 600 Power Transformer has no heater circuit for a tube rectifier. You would need a new PT. Many (if not most) will tell you (correctly, IMHO) it's not worth doing. B/c there is little to no benefit to tube rectification in a single-ended (one power tube) amp. Looks cool though. I like tubes. How did you make out, BTW? |
#20 (permalink) | |
Btw, I made a drawing to clarify your SS rectifier... is this correct? Thanks always! charisjapan
charisjapan * Teleology = Intelligent Design |
