| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
Silvertone 1482 Necessary Mods?
I picked up one of these Silvertone 1482 off ebay a few years back and finally figured I would start modding it when I had time. I was wondering if you guys knew what mods were essential to fix this sucker up. Definitely has a bit of an old appliance that might catch fire vibe on when turned on...
The only "mods" I would do with that one is install a 3 prong power cord, if it doesn't already have one, and maybe replace the electrolytic caps. Those amps sound great without modding the circuitry though so I would leave that as is and crank it up.
Three prong is a must.
And there is no maybe on replacing the electrolytics - that amp is at least 40 years old - it needs new ones. While the chassis is pulled add an artificial center tap on the heater wiring. Also consider replacing your rectifier tube (a couple NOS replacements should prove a lifetime supply) and possibly replace the power tubes. Tremelo tubes take a beating, so that may need replacing too (or not if you don't use the trem.) After all that the next steps I'd suggest would be a stiffer baffle, followed by a newer higher sensitivity speaker. Only then, if I wasn't satisified would I consider modding the circuit. It's true point to point in a cramped layout, and old and fragile, so not exactly easy to work with. |
The main problem with the 1482 is the shallow cabinet.
Installing the amp as is into a 9-10" deep cabinet would make a huge difference in tone, The simplest fix is to install a speaker out jack that defeats the internal speaker when it is used. Through a larger speaker cabinet those amps sound positively amazing. Winnie
I have noticed that happy people are often evaluating themselves and unhappy people are always evaluating others. -William Glasser |
