Old January 4th, 2011, 02:45 PM   #1 (permalink)
EL84 Champ
Just out of Interest would it be possible to use this transformer
http://ampmaker.com/190-0-190v-5w-po...er-1250-0.html
in Vibro Champ circuit and replace the standard 6v6 with an EL84?
Thanks,
Tiarnan
Tiarnan is offline   Reply With Quote
Old January 4th, 2011, 07:13 PM   #2 (permalink)
JohnnyCrash's Avatar
Typical Champ PT may be a bit high in the voltage department (it can be reduced easily though), and OTs are about the same for 6V6 or EL84.
You may consider looking at old Gibson Les Paul Jr amp schematics for a single ended EL84 amp - at least for the power section stuff... or the Kalamazoo Model-1... or... you get the idea, there are a lot out there :)
It shouldn't be too hard to "convert" the power section to an EL84 with the same PT/OT.
3 Gibsons, 5 Teles, assorted other guitars, about a dozen amps, about two dozen pedals, a Smith & Wesson SW40VE, & a .40 SIG Sauer P226R = too many toys, no money, carpal tunnel, and a serious hearing problem.
Old January 4th, 2011, 10:46 PM   #3 (permalink)
printer2's Avatar
http://ax84.com/p1.html
Do a P1 but rather than a TMB tone stack you can use a one knob tone control.
printer2 is offline   Reply With Quote
Old January 4th, 2011, 10:54 PM   #4 (permalink)
The 190-0-190V B+ is a bit on the low-side for EL84's. I'd look for something closer to 230-0-230 @ 50-60 mA minimum for a B+ closer to 330-350V (will sound MUCH better than such a low plate voltage).
Cliff Schecht is offline   Reply With Quote
Old January 5th, 2011, 09:22 AM   #5 (permalink)
Not to second guess anyone, but 190-0-190 is a Push-pull PT spec, innit? Is it a good idea to put 350ishVDC on an SE EL84?
marshman is offline   Reply With Quote
Old January 5th, 2011, 01:01 PM   #6 (permalink)
Thanks guys was just wondering because I have a vibro champ circuit and that transformer. I think ill just stick with a 6v6 and order a weber transformer.
Tiarnan
Old January 5th, 2011, 03:08 PM   #7 (permalink)
Most manuals list 300 v as max plate voltage for EL84 and 350v for 6V6.
limbe is offline   Reply With Quote
Old January 5th, 2011, 04:29 PM   #8 (permalink)
A 190-0-190 transformer will give you around 255v B+ (with a solid state rectifier). Although it's not the maximum voltage for an EL84 it's certainly sufficient to power it. Cathode bias should raise the cathode around 10v, leaving 245v for operation. Perfect - The EL84 data sheets have 250v listed as the example operating voltage. Lowering the voltage dropping resistors to 250-470 ohms on the first drop, 4.7k on the next should keep the preamp B+ near 200v.
Another big improvement on the Champ is to add a filter stage before the OT gets its B+ - around 20uf and 50-100 ohms (2-3 watt). It'll cut the AC ripple hum down to practically nothing.
I'm not sure how much the tremolo circuit would be affected by the lower B+. It might be fine, it might not work at all! I'll let someone else answer that one. :)
-Laird
laird is offline   Reply With Quote
Old January 5th, 2011, 05:20 PM   #9 (permalink)
limbe, actually the 6V6 and the EL-84 have very simular voltage specs. In fact, a quick look at Duncan tube data site shows the 6BQ5 max voltage in AB1 exceeding the 6V6's specs.
And....most guitar amp designs exceed these specs. I haven't seen very many guitar amps with plate voltage below 300V.....and both of these tubes have a max of 285 from what I have seen. Deluxe REverbs often run well over 400V on 6V6 plates. There are technical aspects that account for these tubes ability to tolerate this. Maybe someone will clue us in on this aspect. I simply know that these tubes will operate with palte voltages above their design limits.
Old January 5th, 2011, 06:37 PM   #10 (permalink)
printer2's Avatar
A big variable from what I have been reading is the screen voltage and power rather than the plate. The screen is more fragile and in between the cathode and plate so it makes sense it is more the limiting factor.
Playing around with a 6AQ5 in a SE amp the last couple of days, it is the 7 pin smaller version of the 6V6. It has maximum ratings of 275v for the plate and screen. The data sheet give an example of 250v, was running the amp at that (cathode biased so actual voltage about 240) and am now running it with 300v supply. I have it biased for 43mA and it seems to not mind the voltage. It is just under the dissipation limit for the tube but there is no red plating so it seems fine.
6V6's or EL84's are a little beefier so they could take a little more.
Old January 5th, 2011, 11:37 PM   #11 (permalink)
Telenut62's Avatar
Why not ask the Mr. Amp Man himself....barry@ampmaker.com
He's a really nice guy and certainly kows his stuff. One thing about this EL84/6V6 comparison ain't they got diff pin arrangements, so you'd have to swap the socket as well?
.....I love the sound of distortion in the morning!!
Telenut62 is offline   Reply With Quote
Old January 6th, 2011, 07:28 PM   #12 (permalink)
printer2's Avatar
Different tube socket.
Old January 10th, 2011, 09:37 PM   #13 (permalink)
xStonr's Avatar
will a THD yellow jacket work with existing PT?
xStonr is offline   Reply With Quote
