6BM8 for reverb duty - Telecaster Guitar Forum
Old November 23rd, 2010, 12:13 AM   #1 (permalink)
So, I've got a couple of these things and I got to wonderin' what they might be good for. I took a peek at a BF schematic, particularly the reverb 'section' and see a 12AT7 as driver and a triode of 12AX7/7025 for recovery. Any reason I couldn't use the pentode of the 6BM8 for the driver and the triode for recovery? The transformer should be similar if I understand the datasheet correctly, but where would I get the appropriate "B+" from a typical preamp circuit? Would I need some sort of off the wall/custom PT?
I really need to keep my mind on a leash...
marshman is offline   Reply With Quote
Old November 23rd, 2010, 07:44 PM   #2 (permalink)
You will likely want more gain on the recovery side, but other then that, it looks like a pretty good single tube solution to tube reverb
celeste is offline   Reply With Quote
Old November 23rd, 2010, 09:06 PM   #3 (permalink)
The 6BM8 pentode driver will work really well to drive the verb (as will a 6GW8). Use a gapped SE OT with a 5k Pr Z.
He who dies with the most tubes... wins
tubeswell is offline   Reply With Quote
Sponsored Links   #
Old November 24th, 2010, 12:58 AM   #4 (permalink)
I'm glad that I understood the basics. I have never turned the reverb up in any amp over 3, so maybe I'll be OK with it as is. If I ever get around to implementing it, I'll let you folks know how it turns out.
Thanks
Old November 25th, 2010, 11:31 AM   #5 (permalink)
It seems you are not the first to think this
http://music-electronics-forum.com/a...reverb1_0b.png
Old November 25th, 2010, 10:08 PM   #6 (permalink)
Very cool, big C, thanks for the link.
» Random Photo for Guests
IMG_8202
Fender Logan Custom Guitars
