Old May 3rd, 2010, 01:39 PM   #1 (permalink)
Lead Dress
Is there a rule-of-thumb so to speak concerning lead dress? What I mean is, are certain leads coming close together going to cause more oscillation than others? How should I know which ones will do this?
Thanks.
minions is offline   Reply With Quote
Old May 3rd, 2010, 02:51 PM   #2 (permalink)
The general rule-of-thumb is to separate input leads as far as possible from output leads.
There are of course a lot of other things to think of when you are building an amp.Shielded leads grounded only on one end,heater leads twisted ,hugging the chassie and so on.Go to www.geofex.com.
www.ayanmusic.com/leaddress.htm will give you a few tips too.
Limbe
limbe is offline   Reply With Quote
Old May 3rd, 2010, 03:04 PM   #3 (permalink)
Go here:http://www.geofex.com/article_folder..._tube_amps.htm
Also study as many pictures of the insides of amplifiers as you can.
Topper is offline   Reply With Quote
Old May 3rd, 2010, 06:10 PM   #4 (permalink)
Wires carrying out of phase signals should be seperated. Gain usually means signal inversion. so as Limbe says, seperate input and output. A Cathode Follower has no gain and there is no inversion, no no need to worry about its input vs output. Remember is you have a lot of gain stages, The odd number are out of phase with all the even numbers.
Again, as limbe says twist the heater wires, shoot for 3 turns per inch
Don't forget grounds can be carrying large currents and so can radiate noise magneticly.
Don't use the chassis as a ground conductor. Only two things should be electricly connected to the chassis, the incoming safety ground wire, and 1 connection to the ground network, preferbly at the input jack
celeste is offline   Reply With Quote
