| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
Power Transformer
Is there a way to calculate the amperage of a power transformer? I tried doing some calculations myself, but it always comes out fubared.
Thanks! |
If it helps, the schematic gives 280VAC for the secondary (I assume when the amp is on and the tubes are drawing current), and the signal tubes are drawing about 49mA total. I would use Celeste's procedure -- hook up the PT to exactly 120VAC input (do you have a variac?), measure the unloaded voltage on the secondary, then load it down until you get a 10% drop.
- Scott
Wound thirds are my anti-wank. |
