| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
First build question
EDIT: this question answered, but there's more questions below
I'm sure you guys don't get sick of these questions huh? I'm just confused about the schematic/layout for the princeton reverb. I'm coming up on the last stretch of wiring the board to the sockets/pots/power. Up until now I've ignored it, but now I gotta know. In some areas of the amp, it shows a wire leading off and then terminates in a box that has a letter in it like D, B, or X etc. I cannot for the life of me figure what the hell those boxes are supposed to represent. Last edited by mraymond77; April 10th, 2010 at 01:29 AM. |
Those letters in boxes represent power supply nodes. They just did that to eliminate some of the crossed lines on the schematic. (B is the cap-can terminal with the square, D is the terminal with no symbol next to it.)
Hope this helps, - Scott
Wound thirds are my anti-wank. |
If you look at the layout, you'll see a corresponding letter. This means that "D" in one location on the board needs a wire/jumper to attach to the other "D" on the board.
- 3 Gibsons, 5 Teles, assorted other guitars, about a dozen amps, about two dozen pedals, a Smith & Wesson SW40VE, & a .40 SIG Sauer P226R = too many toys, no money, carpal tunnel, and a serious hearing problem. |
I see. I guess the weber layout confused me because some letters that dont have partners such as Y. but on the fender diagram there are partners. well, I checked and I do have all those wired up correctly, so another question for ya. Must I put a grounding wire across the top of my board (the one that looks like a handrail)? I wanted to just ground all those points by wiring it to the bare ground wire I soldered across the backs of all my pots. but that may cause noise I'm guessing?
well I turned it on for the first time. fortunately sound come through the speaker, but not much of it. even cranked to 10 it wasn't that loud and had a nasty distortion. what could cause low volume? also how many mA should I bias a princeton reverb to?
I think we all love pictures, so heres some pictures.
http://www.flickr.com/photos/49163479@N05/?saved=1 Looking at these pictures, I think I didn't ground my speaker jacks and rca jacks properly. I didn't string them up and wire it to my ground point. Could that be a cause for Noise, low volume, and lack of tremolo? I sure hope so. I'm a bit concerned about my bias circuit. I just fashioned it out of some spare board I had and screws. I didnt have eyelets at my disposal, so it's really just wires twisted together. I figure it should still work, but I wonder if its a problem. |
First off, I think you should pat yourself on the back. We're not always lucky enough to get sound at our first powerup!
What are you getting for your bias voltage? Overbiased tubes will have a pretty ugly distortion even at low volume levels. While you're in there, what are you getting for the other power supply voltages? One thing I would do is find a way to wire 1-ohm resistors from each 6V6 cathode to ground (instead of connecting each cathode directly to ground.) When you measure the voltage across that, it will also tell you how much current is flowing through each tube. Multiply that by the plate voltage, and you'll get each tube's plate dissipation (well, plate and screen, but close enough). Most of us would like to see that number under about 10 watts. - Scott
#10 (permalink) | ||
Make sure you ground buss is really grounded. Solder a wire to one end of it, solder a ring terminal to the other end of the wire. Scuff off a spot on the chassiis and tie your ring terminal down to it with an 8-32 or 10-32 machine screw with toothed washers. Double nut it so it can't get loose. ...which I see you attempted to do. The ground point is over by the cap can, right? Soldered or bolted? Soldered doesn 't work well on aluminum unless you put a lot of heat to it. Use a soldering gun on the high range. If you used the same pencil type iron as you used to assemble your board that might not have been enough heat. ...you also might want to isolate your preamp ground from your power supply ground. Your filter caps are going "burp, burp, burp" (only faster! There are two philosophies, one is to star ground everything. That means pick a ground point, it's the only ground point in the amp and all grounds go to that via long wires. You can go semi-star ground or buss ground using two ground points, one for the preamp and the other for the power amp/power supply. In theory ground is ground and it's all supposed to be the same ground. One side of the chassis is supposed to be exactly the same as the other so in theory you could drop a ground anywhere. Look at any '60s or '70s Fender, there are grounds everywhere. You frequently won't see a lot of ground points in something more sophisticated. A solid ground eliminates a lot of noise. A poor ground is the opposite, your amp will be noisy. |
#11 (permalink) | |
If those connections aren't soldered they should be. Cadmium plated machine screws aren't the best conductor and they take a lot of heat if you attempt to solder to them. Good hardwares stores still sell copper tacks or better yet, forked brass rivets. Fastenal gan get you forked brass rivets. You could of course ping Turretboards.com http://www.turretboards.com/ and get the real thing, eyelets, turrets. staking tools or fully assembled solder ready turretboards. But... if you're into Steam Punk improvised circuits built right now from locally available material brass tacks will do. |
#12 (permalink) | ||||
sorry about my lack of knowledge here, To get some other power voltage readings what pins should I probe? this is the cheap multimeter I have. http://www.smcelectronics.com/PICTURES/DVM1-L.JPG which setting should I use? sorry, so many questions!! Quote:
I guess my biggest problems are the low volume, and tremolo. when I turn the tremolo speed up, it starts out with a fast "b,b,b,b,b" sound and as I turn it up higher the "b,b,b,b" gets even faster. when I turn up tremolo intensity, I just get a deep bass-y sound that gets a bit louder as I turn it up. neither seem to effect my guitar signal Reverb works great, and so do bass and treble knobs. Last edited by mraymond77; April 10th, 2010 at 03:07 PM. |
Alright I went in and measured some voltages. on the power transformer, I got 387 on the yellow wires, and 327 on the red wires.
On my cap can, I get 382 for the square, 374 for the D, 290 for the Circle, and 227 on the last one. each respectively %10 less than stated on the schematic. I went through several points in the amp and anywhere that it tells voltage on the schematic, I measured my own and wrote it down. pretty much all of the measurements are about %90 of what is stated on the schematic for their respective points, give or take a percentile or two. it says on the schematic that measurements can be within a %20 difference range, so I dont know if its ok, or if my transformer is weak? The only measurement I took that was inconsistent with the others was on V4 pin 1. I came up with 203 V which is only 78% of the stated 260V. The voltage before the 220k resistor matches the measurement at the cap can D at 374, but after the resistor its lower than I think it should be. bad resistor? I don't know how big of a deal it is in the first place. Can anyone give some insight? |
#14 (permalink) | ||
Howdy mraymond77
You'll be asking where are all the usual experts when you need them? In lieu of that here's my advice #:o) Quote:
Out of interest, as I see you seem to have installed a bias-pot to tweak the bias; What bias voltage are you getting between the two 220K resistors that connect Pin5s of the 6V6GTs, with the tremolo set to minimum? Quote:
Make absolutely certain that the wiring is correct before looking for faulty components. Last edited by Blue Whale; April 14th, 2010 at 10:46 PM. Reason: woops typo, meant to I "wouldn't" et cetera ... to damn hot here today |
Those voltages are a little low, but the amp should work fine and deliver a good majority of the rated power. Is this a Weber kit where the PT has 120V and 125V primaries? What does your wall voltage read? If you wired up the 125V primary and you've only got 122V coming out of the wall, all of your voltages will be proportionately lower. Is your 5U4 old and tired?
What bias voltage do you see on the grids (pin #5) of the 6V6's? If you're running a hot bias, that will bring all the voltages down. - Scott
#16 (permalink) | |||
I get -28V on either side of the resistors, and -34 before the resistors Quote:
http://www.tubesandmore.com/scripts/...item=P-TF22772 maybe its a cheap-o tarnsformer. I hope I don't have a bum 5u4! Its a brand new JJ just got it from eurotubes. the voltages I got on pin 5 were both about -28v. thanks you guys rock! great to have some advice on where to check |
#17 (permalink) | |
Did you double check the under board wiring, easy enough to stick a meter on for continuity and check; - that V4 Pin2 goes the the 1M resistor on the far side of the board - that Speed-pot takes lead goes to junction of the .1uF&.2uF caps - and that the Intensity-pot joins at the other .1uF on that side of the board I'll think on about your issue later ... in the meantime, this will probably seem too obvious but, have you tried a different 12AX7/7025 in V4? Just that a dodgy V4 would account for both tremolo & vol (re V4 also phase inverter) issues, otherwise can merely suggest rechecking all V4 connections, correct, good earths, and voltages ... certainly seems an issue surrounding V4. Last edited by Blue Whale; April 15th, 2010 at 03:12 AM. Reason: I should really learn to look at the monitor when typing or at least after I've finished #:o) |
#18 (permalink) | |
Personally, I think the PR runs excessively-high voltages on the output tubes for the power it gets from them. - Scott
