| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
Annoying crackling sound?
I've got a Pro Jr. that I modded myself that is making some loud crackling noises once it heats up. First I thought it was tubes, but I replaced them with new ones and it's still doing it.
Everything was fine for a few months, but now it's making this horrible sound. It's an intermittent crackle -not feedback- that is about as loud as the note being played. The note is still audible, but it crackles along with it. It's fine until I've been playing for a few minutes, then it starts it's racket. I've tried plugging it into a different speaker, but it still does it -so that ain't it. Any ideas?
"Son, always eat your vegetables.... and stay away from those whole tone scales!!" |
#2 (permalink) | |
Check all ground points.
I had an amp once that sounded great for about 20 minutes into playing and then all of a sudden it would produce this loud crackling/screeching sound. It was somewhat random as it didn't always do it. Drove me crazy trying to find the problem. One day I just went in and resoldered all the ground points and viola, problem solved. I don't know if there was a cracked solder or maybe a cold solder or what but now I always touch up all ground points as a matter of routine. |
Thanx for all the tips and help guys. I'm gonna have to get back inside it and check/re-solder all of the mods I did.
Although I love my Pro Jr., it's a real PITA to work on. It's REAL tight in there. This was the first experience I've had working with PCBs, so it's probably my solder joints. The loose tube socket may be at issue, but since they're not screwed in, tightening them is not really an option. These amps are very cheaply made. I'm hoping that that's not the problem.
I had a problem with a Pro Jr shaking the tubes in their sockets when it was turned up loud. You might try the PJ as a head with an ext. speaker to see if it's a vibration thing. As I recall, mine didn't have any cans or clips to hold the tubes in place.
Those intermittent pops and crackles are usually voltage changing somewhere in the signal path. If the output tubes are okay (and they probably are if it happened only after you did your mods) then check for solder and of dirty flux residue between traces/trace pads, and also on/in the pots themselves. The trouble with those pots that are mounted on PCBs, is that they can twist and strain the joint when you tighten them up, either affecting the traces or the pots or both. Or you might've got some flux or solder residue causing unwanted voltage leakage on a PCB or inside a pot itself (if you soldered directly onto a pot - esp if it was tipped on its side/end in such a way that that solder could run down into the pot. 2CW
#11 (permalink) | |
I inspected the sockets, made sure the tubes were seated properly, and did a couple of other things that were recommended. The amp works fine now!! Thanks all!
| Annoying clicking sound | Clive Hugh | Just Pickups | 0 | November 17th, 2007 08:09 PM |
| Crackling sound in DRRI? | Kurt | Amp Central Station | 4 | November 18th, 2006 11:24 PM |
| I think I have the crackling sound fixed!!! | Debbie | Amp Central Station | 3 | November 27th, 2003 12:02 PM |
| Crackling sound in new maz junior what could it be?? | Debbie | Amp Central Station | 9 | November 25th, 2003 07:07 PM |
| I'm getting a crackling sound | geddyleedog | Tele-Tech | 2 | April 26th, 2003 12:27 AM |
