Old November 2nd, 2009, 09:29 PM   #1 (permalink)
Vox Pathfinder Question
I am replacing the 8 inch speaker in my Pathfinder with a 10 inch one, have everything ready but one problem...
Like an idiot I didn't pay attention to what wire was postive and which was negative going to the speaker. There is a black wire which I am guessing is the negative but wanted to make sure.
Any Pathfinder owners out there know which wire is positive and which is negative to the speaker?
Thanks!
jmtaylor22 is offline   Reply With Quote
Old November 2nd, 2009, 10:47 PM   #2 (permalink)
Ben Harmless's Avatar
Well, guitar speakers are fundamentally AC devices, so as long as all the speakers in a given enclosure are connected at the same polarity, there shouldn't be a problem. In the case of a single speaker, it plain doesn't matter unless you are running another amp along with it that happens to be of the opposite polarity.
That being said, if you want to do as Vox does, the black wire is hooked up to the positive terminal in my Pathfinder, and the white to the negative.
- B. Simpson
"...Because we all expect the truth, we must be the best of fools."
- Stiff Little Fingers
Old November 2nd, 2009, 10:57 PM   #3 (permalink)
Awesome thanks!
Old November 2nd, 2009, 11:10 PM   #4 (permalink)
I put a 10 inch Rajun Cajun in the Pathfinder, and first play I am really digging it. I made a new speaker baffle and covered it with some Vox grill cloth. The magnet is a tight fit, I put some rubber washers on the chassis to keep it from getting sucked right onto the magnet.
It definitely opens the amp up quit a bit, the overall sound is much clearer. It really is a nice sounding amp stock and the 10 inch really lets it breath.
Old November 2nd, 2009, 11:20 PM   #5 (permalink)
You know, I've been singing the Pathfinder's praises for years, and I've sworn that it's one of the better clean tones out there under $1000. Every time I've used it to record, however, I've run it through a different cabinet. Hence, I've been thinking about doing a 10" swap myself.
...On the other hand, I'm piecing together a Champ build, so maybe I'll leave well enough alone.
- B. Simpson
Old November 2nd, 2009, 11:49 PM   #6 (permalink)
Ah, the British. Warm beer and postive ground...
Take it to a tech.
Old November 3rd, 2009, 12:24 AM   #7 (permalink)
LOL. That was my thought too, but who am I to question?
- B. Simpson
Old November 3rd, 2009, 12:38 AM   #8 (permalink)
Hiker's Avatar
Shhhh! This well-kept secret might get out! When I located a used Pathfinder without the reverb this Summer for $39.99, I grabbed it!
Hammer On!
Hiker is offline   Reply With Quote
Old November 3rd, 2009, 08:50 AM   #9 (permalink)
Yeah it is a great amp. I've tried just about every small practice/recording amp for under $600, and this Pathfinder is my favorite which is hard to believe for a ~120 dollar solid state amp.
It's quiet, and the clean sound is just fantastic to my ears. The 10 inch speaker is definitely a nice upgrade, the bass is obviously a lot better, it balances out the nice chimey high end that it has.
I played some more with it this morning and was able to turn it up a bit more and it is just fantastic.
It is a lot heavier now! The magnet on the Cajun is huge compared to the stock speaker.
Old November 3rd, 2009, 08:57 AM   #10 (permalink)
Sidney Vicious's Avatar
jmtaylor22 I see you are in Covington - I'm in NO:
There was a Vox Pathfinder with reverb in the head and 2x8 setup - with footswitch - for only $200 in the Baton Rouge Craigslist just the other day - THAT is a great Pathfinder and may be worth a look - I would get it myself but am trying to unload amps . . . .
Edit to note - its still there:
http://batonrouge.craigslist.org/msg/1428170889.html
Sidney Vicious is offline   Reply With Quote
Old November 3rd, 2009, 11:02 AM   #11 (permalink)
momotrucker's Avatar
any recommended settings for clean tone on the pathfinder?
momotrucker is offline   Reply With Quote
Old November 3rd, 2009, 11:43 AM   #12 (permalink)
Well it is pretty basic and a lot will depend on your guitar I think. But right now I have something like
Gain: 9 O' Clock
Volume: 12 O' Clock
Treble: 1 O' Clock
Bass: 1 O' Clock
Tremolo:Off
Depth:Off
Reverb: (To taste)
Old November 3rd, 2009, 11:55 AM   #13 (permalink)
shinigami747's Avatar
i use something similar to what was posted previously.
gain: 9:30
volume: to taste
treble: 1:00
bass: 11:00
trem/reverb: usually off
the guitar is the human soul speaking with just six strings
-from beck: mongolian chop squad
shinigami747 is offline   Reply With Quote
Old November 3rd, 2009, 12:30 PM   #14 (permalink)
mistermullens's Avatar
jmtaylor22, glad to see you got this one figured out. Thanks for the comments on my YT vid. So are you in Covington, GA or another Covington?
Jonathan ReverbNation Twitter Teles & Esquires
Old November 3rd, 2009, 12:53 PM   #15 (permalink)
I prefer pickups with more midrange, so my clean tones tend to involve more of the treble and bass controls. Something like:
Boost: off
Gain: 9-10 o'clock
Volume: whatever - usually around 12 o'clock
Treble: 2-3 o'clock
Bass: 11-12 o'clock
I don't really use the 'verb. Trem only when I'm doing some Link Wray or the like. When I'm running dirty, I usually crank back the treble some, and the bass most of the way, as the amp can get a bit muddy with too much low end. This applies both to the amp's own dirt, or pedals run into the front.
- B. Simpson
Old November 3rd, 2009, 05:33 PM   #16 (permalink)
Lot's of Covington's around! I am in Covington, KY. near Cincinnati.
Old November 3rd, 2009, 10:33 PM   #17 (permalink)
Vox Pathfinder 10! mistermullens Amp Central Station 4 June 19th, 2009 05:30 PM
VOX Pathfinder 10 owners question.... Robster Amp Central Station 4 May 29th, 2009 02:04 PM
Another way to have fun with the VOX Pathfinder 15R..... studio1087 Amp Central Station 3 May 13th, 2009 12:12 AM
VOX Pathfinder 15 amp alexpigment Amp Central Station 24 June 1st, 2008 05:07 AM
Vox Pathfinder 15W Blues Hurler Amp Central Station 15 January 7th, 2004 08:43 PM
