Old October 28th, 2009, 01:25 PM   #1 (permalink)
BigDaveyTwinkle's Avatar
Bass Cabinet Speaker Swap ?
I have a new (low mileage) Acoustic Amplification B115 cabinet with a speaker rated at 250w @ 8 ohms. I have an SWR Workingman's Pro B115T cabinet with unknown mileage/use on it that I just bought as part of a bass stack, with a speaker rated at 200w @ 8ohms.
Would any of you pull the Acoustic 15" and swap with the SWR speaker?
I am trying to weigh the advantages of having a newer, higher rated speaker in a cabinet against having to disclose the reduced speaker when I go to sell the Acoustic cabinet.
For what it is worth, I am running a 500w head through a 400w 4x10 and the 15" cabinet that I may be swapping speakers in.
Thanks in advance -
BDT
"Music is love in search of a word." - Sidney Lanier
BigDaveyTwinkle is offline   Reply With Quote
Amp Cabinet Swap xStonr Shock Brother's DIY Amps 0 July 21st, 2009 09:35 PM
speaker cabinet build- speaker placement in a 4x12 telebluesrocker Shock Brother's DIY Amps 1 June 21st, 2009 06:17 PM
P-bass swap with J-bass bridge? Deaf Eddie The BASS Place 15 May 28th, 2008 11:24 AM
What makes a speaker cabinet a good cabinet? sean79 Amp Central Station 19 November 10th, 2006 10:31 PM
Speaker swap moparmutt Amp Central Station 3 August 7th, 2006 07:10 PM
