Old October 27th, 2009, 11:33 AM   #1 (permalink)
RockStarNick's Avatar
Quick Q: Resistor across a gain pot
If a gain pot is 1Meg, and there's a resistor across the lugs it, the resistor is in parallel, therefore DECREASING the available gain, correct?
GEAR: Fender US Tele Sunburst • Blackguard Blonde Tele • Fender US Strat • 2 Warmoth HB Tele Deluxes • Warmoth Thinline Gretsch-o-Caster
RockStarNick is offline   Reply With Quote
Old October 27th, 2009, 11:43 AM   #2 (permalink)
Depends what value resistor, and which lugs. Post more specifics.
Old October 27th, 2009, 03:52 PM   #3 (permalink)
OK there's 2 1MEG gain pots, one for each channel.
One of them has no resistor, and the other one has a 220K ohm resistor on it, I believein paralell.
The one with the resistor should yeild lower gain, correct?
Old October 27th, 2009, 03:59 PM   #4 (permalink)
Ben Harmless's Avatar
Still depends.
What sort of amp are we talking about here? Is it something we could look at a schematic for (i.e. a classic Fender/Marshal/other design)?
- B. Simpson
"...Because we all expect the truth, we must be the best of fools."
- Stiff Little Fingers
Old October 27th, 2009, 04:25 PM   #5 (permalink)
It's actually a newer modular design amp, like the Randall MTS series. Definitely not a classic design, but a pretty standard gain pot, I'm guessing.
Old October 27th, 2009, 07:54 PM   #6 (permalink)
Still lots of questions unanswered.
If we number the pot lugs 1, 2 ,3, with the wiper being 2 and the resister going from 1 to 3 then what you have is about 180500 ohm pot.
Now how that pot is connected to the rest of the circuit to control gain will decide which channel has more gain.
celeste is offline   Reply With Quote
One, 1 Ohm resistor icd Amp Central Station 4 May 25th, 2007 02:48 AM
Recommended Resistor quackerz Amp Central Station 8 December 13th, 2006 03:40 PM
Where can I get a 270K resistor? Jason R. Telecaster Discussion Forum 17 October 20th, 2006 05:51 AM
This is a 330 ohm 1 w resistor right? Doc Amp Central Station 4 June 12th, 2004 01:59 AM
Blend and the 15k resistor Mark Davis Tele-Tech 2 March 25th, 2004 06:10 PM
