| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
How to drop B+ with zener, explained to a 5 years old child?!
Hi all,
What should be connect to ground, anode or the cathode? What value would you recommend in order to drop 20V? Anyone has pictures of a zener installed on a 5E3? Thanks for any imput |
Hi, I've done this. Here's a link which explains it:
http://music-electronics-forum.com/t563/#post52097 steven
"When you have to kill a man it costs nothing to be polite" - WSC |
The zener needs to be really big, take the desired voltage drop X the max current then double it for safety margin. Likely a 5 watt zener is not going to do it. Larger zeners come in odd form factors and here Weber sells them on brackets that are easiely mounted to a chassis. This is not my favorite way to drop voltage, but it works, it is relieable if done correctly and it is easy, all good things. I am not connected to Weber, I just know that for the fisrt timer, their kits make success easier to achieve.
You choose a zener of the voltage you want to drop. A 20v zener will drop 20v from the B+ |
#10 (permalink) | |
(If anyone knows what they are talking about, its Bruce Collins) |
| Need Help Zener Installation | Spaceclam | Shock Brother's DIY Amps | 10 | March 9th, 2009 01:49 AM |
| Compressors Explained | SixStringSlinger | The Stomp Box | 7 | May 11th, 2007 06:58 PM |
| Highway 1's demoed and explained | casterway | Bad Dog Cafe | 1 | February 18th, 2007 12:08 AM |
| Hey J Stokes and other Fender afficienados... Stock zener? | Tim Swartz | Amp Central Station | 10 | September 9th, 2005 01:37 AM |
