| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
I have no slippage on my clippage.
Seriously i have never had an issue and it is easier to experiment/ change speakers. I give an extra crimp to the clip with my strippers and have never had an issue. With soldering I worry about overheating the terminal and having the small extension wire to the speaker come off. It happened to me before (not due to soldering) and it was a pain to get back on. |
You may have noticed that speakers vibrate and clips can work loose. After a few years the contacts corrode, which makes for some small extra resistance. Clips are only marginally quicker than the soldering iron. I solder.
#8 (permalink) | |
Clips are the best way to go, and the easiest to maintain. That is the key word, "maintain". A clip can be easliy realigned with a pair of needlenose and and cleaned with some steel wool. Soldered wires require a soldering iron, which requires power that is notalways readily available. Both are viable, but the clip has the definite edge.
I would rather be a jack-of-all-trades and master of none, than be a one trick-pony out of a job. |
CLIPS
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body,but rather to skid in broadside,thoroughly used up,totally worn out,and loudly proclaiming:"WOW,what a ride!" |
If you're looking to A/B some drivers to get a sense of what you like in a particular cab, sure, go for the clips. But once you've decided on what you want to use, solder it up!
A well-soldered connection isn't going to break. |
never had a problem with clips!
toadman the plank spanker www.slugnickel.com www.zydecohogs.com "The ultimate result of protecting man from folly is to fill the world with fools" Herbert Spencer
#14 (permalink) | |
Of course, if you are not confident in your soldering ability, best to stick to the clip method. For a temporary installation, clips are plenty good enough. Last edited by Ricky D.; October 22nd, 2009 at 09:28 PM. |
#17 (permalink) | |
I have had numerous problems with those wretched spade clips, mainly on the car, wires pull out of the crimp, the slot opens up and becomes loose, the plating oxidises and the electrical contact fails. I've had amps make disaster threatening loud crackling 'blown speaker' noises, traced to a loose one on the speaker. Yes a soldering iron requires power, presumably the same stuff you plug the amp into.
#19 (permalink) |
Most designs can be improved on, question is, how strong/conductive does a connection have to be to be strong/conductive enough?
Solder is probably better, I use clips...I don't solder the mains lead either.
The world is full of busy people, might be a better place if some of 'em spent more time on their arses... |
#20 (permalink) |
Ted Webber says solder
I once posed this question to Ted Webber of Webber VST and he recommended soldering the connections. I always solder the speaker wires.
It would seem to me a good approach is that if you intend to try different speakers to use clips until you're happy and then solder the final choice. Steve |
#21 (permalink) |
I'll just go ahead and point out that there are thousands upon thousands of Marshall 4x12 cabs that have lived in trailers and been gigged hard for decades - and use clips.
The amount of vibration that is required to bend a clip and cause it to fail over time could just as easily cause a solder joint to fail. Those spade connectors, when properly used, are very tough to disconnect, and I've had them come loose from the wire when trying to remove them from speaker terminals.
#22 (permalink) |
In a combo cab where you're putting footswitch wires, power cables etc in and out all the time, soldering is a must, but that's not enough - also zip ties to hold the speaker leads in position so if the speaker cable gets bumped or yanked it won't stress or pull on the solder connections. In a closed back cab clips are less of an issue but can still come loose, I use the same philosophy, partly because in my experience everything that can come disconnected will eventually do so, at the most inconvenient time, with the maximum possible damage caused.
#23 (permalink) |
My speakers don't need wires, they already KNOW what to do. j/k
I usually clip if there are clips, and solder if there aren't. Actually I just did some speaker swapping and I went to Walmart and bought terminal clips just in case I need/want to change again. Radio Shack did not have terminal clips. I wish I could say that was surprising, but I'm becoming all to accustomed to walking out of Radio Shack in disappointment. |
#24 (permalink) |
I crimp and then solder the wires to the clips and make sure the clips are secured very tight on the terminals: I need them to come off when I really want to without breaking out the soldering kit, but stay tight because I stuff cables in the back. This way the terminals will break off the speaker sooner than the clips will slip.
#26 (permalink) |
Chewing gum and tinfoil
DISCLAIMER: Just because I said it doesnt mean you should do it. As always, wear your rubbers, probe with one hand, and make sure you have discharged everything. |
#27 (permalink) |
Yeah one of best around does-it-all fix materials. But like everything else Gum just ain't what it used to be
But duct tape can still be good as long as you source it from your local hvac builder. But even that is under assualt now out here in Cal. siggghhh. Texas seems to be the only place to still h.i.s.t.- I assume the gum is still good over yonder in Tex.
#28 (permalink) |
Temporary = clip.
Best electrical connection = proper solder joint, affords more contact area than the mechanical clips for higher current connections. I was taught that solder is not an adhesive, so if it broke you did not strain relieve it (i.e. follow lead dress) properly for the operating conditions. $.02 Jack |
| Where do I solder my ground wire to? | Lewins | Tele-Tech | 5 | November 30th, 2008 09:59 PM |
| solder splatter on speaker cone. problem?... | vanguard | Amp Central Station | 4 | January 11th, 2008 08:38 AM |
| Wire and solder type for guitar wiring - suggestions?? | maxsmith | Tele-Tech | 9 | October 14th, 2005 06:49 PM |
| Wire and solder type for guitar wiring - suggestions?? | maxsmith | Telecaster Discussion Forum | 3 | October 7th, 2005 01:02 AM |
| Well, almost ready to wire her up...which solder should I us | Hank Seiz | Tele-Tech | 2 | April 25th, 2003 01:32 PM |
