| Shock Brother's DIY Amps Building or modding your amp? Then use this forum to discuss the process and show your pride and joy. |
VOX AC15CC Blowing Fuses
My Vox AC15 has always worked great and hasn't been modified in any way. 2 Years ago I replaced the valves, and the 'new' ones have sounded great!
I played it a few nights ago for an hour or so, and everything was fine. Now it's just blowing fuses. It wouldn't power up at band prac and I figured it was prob a fuse that had gone. Got new ones today (T800, 250V) and the power light comes on for half a second before dying. I've removed all tubes and tried, but it's doing the same. HELP!!! I've done some work on amps and know how to discharge filter caps etc, where do I start with this? |
me too with my '96 ac30. cheap chinese rectifier tube kept arcing every once in a while when i'd push it with a fuzzbox. hardest thing to locate until i brought all the gear down to the shop and played for a while. i'd swap out the rectifier first and see if that solves it.
The AC15CC does not have a tube rectifier. First thing to suspect is bad power tubes, second thing to suspect is bad preamp tubes. So swap the power tubes to good new ones, and if that wasn't it swap the preamp tubes to good new ones. If you don't know what to do if that doesn't fix it, take it to a tech. Blowing fuses is never caused by a weak fuse, something is drawing too much current.
#6 (permalink) | |
- Scott
"The chorus pedal is God's gift to the untuneable guitar." - Peter Holsapple |
So, I sent the amp to a tech and he found a short-circuit. Turns out that legs of two components were protuding so far through the pcb that they were touching the chassis!!!!! He thinks that they weren't originally touching, but that the board has lost a bit of rigidity of the years.
So, short circuit fixed, BUT it's damaged my PT I'm going to replace it but I'm trying hard not to use a Vox part as I've heard that there have been a few faulty ones around. It's not easy to get alternatives in the UK, anyone got suggestions? |
| Twin Reverb RI blowing fuses | RotelliCaster | Amp Central Station | 21 | May 20th, 2009 04:57 PM |
| Bassman RI blowing fuses | Del Pickup | Amp Central Station | 26 | June 26th, 2008 04:40 AM |
| new 5F1 blowing fuses | TelZilla | Amp Central Station | 6 | April 9th, 2008 02:31 PM |
| New AC30 CC1 blowing fuses | Chris Truman | Amp Central Station | 3 | April 22nd, 2006 01:07 AM |
| Carmen Ghia keeps blowing fuses | Dana | Amp Central Station | 11 | December 14th, 2004 06:12 PM |
