Old June 17th, 2009, 11:43 PM   #1 (permalink)
advice needed for a 5f2a mod
Pulled the trigger on the parts for my first amp build yesterday... but I could use a little advice regarding a mod I'd like to make to use a 6L6GC as the power tube. Take a look
big-daddy-59 is offline   Reply With Quote
Old June 18th, 2009, 12:05 AM   #2 (permalink)
Tele-Dave's Avatar
Make sure you get the proper OT. The 6L6 likes to see a load resistance of about 4200-5000 ohm, whereas the 6V6 likes to see 6600-7000 ohm.
_____________________________________________
"no complaints yet, but it's still early"!!!
Tele-Dave is offline   Reply With Quote
Old June 18th, 2009, 12:41 AM   #3 (permalink)
petebradt's Avatar
You beat me to it. If you try to run 6L6s in a stock 5F2A you're liable to pop the OT.
petebradt is offline   Reply With Quote
Old June 18th, 2009, 02:35 PM   #4 (permalink)
okay , upgrade output tranny.
Would this be a good choice?
Old June 18th, 2009, 02:45 PM   #5 (permalink)
muchxs's Avatar
5F2A w/ WSE15 = NO PROBLEM!! Use the stock 470 ohm cathode resistor and you'll be able to switch from 6V6 to 6L6 any time.
Your taps become 4, 8, 16, 32 with a 6V6 if you want to get hung up about it. A 10k load on a 6V6 is a little high. You have a choice of a little high or a little low, I'd go high.
There's enough room on the 5F2 chassis to add a barrier strip between the circuit board and the PT for the extra taps.
