Audio Interface
Im trying to do some research on audio interfaces for studios....I found one tha I like...it's pricy but I want to know if it's any good....and if anyone has ever used it.
here is the link....it is the Echo AudioFire 12 http://www.8thstreet.com/product.asp...dio_Interfaces please everyone let me know your thoughts on it or if there is a better one, maybe one cheaper. thanks muusicman |
That unit has no mic pre-s or HiZ instrument inputs. Will only take line level signals as is. So if you were planning on directly tapping into it with mics or guitars your out of luck unless you have the outboard gear to compensate. The sampling rate is phenominal but in all honesty most at the hobby level are recording at 44.1khz and few seldom at 96khz primarily because the wave files become too large and alot of software based effect, especially synths, won't function properly beyond 96khz. Purely speculating but if the sample rate is that high, they unit probably has very good converters. It also supports Windows Vista and alot of other companies haven't released Vista drivers yet.
Presonus Firestudio is the only alternative I can think of if you need that much IO. Same price but I think it's more flexible for someone who doesn't have additional outboard gear. Google Mark of the Unicorn too (MOTU), they probably have something similar but are usually a little more pricey. Do you eally need that much I/O? |
It actually says that it does have mic pres - although they are probably accessable through a menu hiearchy or accompanying software, much like my MOTU Ultralite.
As with Stu - I would ask if you really need that much in/out. Will you be recording single instruments mainly - or would you foresee needing to mic a full drum - kit. Do you need outputs at all? Will you be re-routing signals to outboard gear? As an example - my MOTU Ultralite has 8 ins and 10 outs (not counting SPDIF, ADAT, etc. - which I will never use). It has two combination XLR/TRS inputs and mic pres on all channels - although only two are accessible from the hardware. They also make a unit called the 8pre which is 8 inputs - mic pres for all and two outs for monitoring. It's comparable in price to the Ultralite - in fact, I'm thinking about adding it to my system just to have more XLR inputs. The 'big daddy' MOTU 896 has all the bells and whistles including phantom power and mic pres for all channels. So for the Ultralite or 8pre - you're talking $549 and for the 896 - $1k. But the great thing about a company like MOTU that makes lots of different products is that they integrate seemlessly, so you can purchase the 8pre for example - then if you decide you need outputs - add another unit like the Ultralite. If you really like this unit - there are ways around the TRS input problem - such as an XLR input box to TRS snake.
www.thegearspy.com |
Moderator
I just bought another M-Audio Delta 1010lt for $199 from MF. Two of them give me 16 in/out (and more if I use the S/PDIF) plus midi in/out.
If you have PCI slots and don't mind having your computer hard-wired, it's a much less expensive way to go, and the quality is as good or better... Cheers, Tim
http://www.moodswingers.org |
I don't think this does have mic pres at all Cacabi. I just downloaded the manual covering Audiofire 2 up to Audiofire 12. Their Audiofire 8 has some though are you looking at that one?
In the specs from the manual it says 12 balanced TRS inputs nominal input level at +4dBu (that's the output voltage coming off a studio mixer) or -10dBV (that's the output voltage from home audio/video equipment). From muusicman's link, "If you already have a mixer and tons of microphone / instrument preamps, but you need to get all that audio into your computer then the AudioFire12 is just for you." |
#7 (permalink) | |
12 in/12 out Firewire Audio Recording with Preamps
Here's some reviews on it.
http://www.musictechmag.co.uk/mtm/download/audiofire-12 http://www.soundonsound.com/sos/oct0...oaudiofire.htm |
Im starting to think that all this stuff I need to buy for a studio is more trouble than it's worth....I live on a fixed income...Im lucky sometimes to come out with 100 dollars at the end of the month so I think im gonna have to focus my attention and money onto something else....any sugestions?
The card Tim mentioned if you have an extra PCI slot in your computer.
Your right here it is so so easy to get carried away. One step at a time. What exactly do you want to accomplish. A little hobby with you producing your own solo type musak? You can do this on the cheap and get good results. |
#11 (permalink) | |
Moderator
Cheers, Tim
#12 (permalink) | ||
Moderator
Do you need to record a lot of tracks simultaneously? Before I got this 8-channel soundcard, I had a $99 stereo soundcard on my computer, an Cheers, Tim
#13 (permalink) | |
Mac |
#14 (permalink) | |
That's the one that I use. It's great - especially for very expansive drum mic'ing. I like it. Shawn
#15 (permalink) | |
I sympathize. What do you mean by "studio?" Do you want to be able to record bands like on 48 tracks? Or do you just want to be able to lay down tracks one at a time? If it's the latter, it doesn't have to be expensive. You have a computer. You can use a free DAW like Audacity. Here's my real hardware costs Mackie Onyx Satellite--$199 M-Audio BX5 monitors--$199 "reconditioned" from musiciansfriend 2 MXR condenser mics--$100 Shure sm 57$ 100 You could do without the monitors, and just get a decent set of headphones and you don't need the SM-57 unless you absolutely have to mic cabs. More and more I don't bother, I just run direct and use a sim Cacibi makes a great point about the MOTU stuff--I use a Mac and if I had more money to spend I'd get a motu ultralite and add on as needed. But I think I've gotten good results laying down tracks with this simple rig. Here's a page of samples |
