buzzy distortion
I've been doing some recordings, and I'm getting some very buzzy distorted tones. There is either too much high end, or it sounds like bees. The gain is turned way down, so there is not very much distortion at all, and I've tried moving the mic all over the speaker, straight and angled.
The mic is a Sennheiser e835 running through the ART preamp, into the computer. Any tips? |
Try pointing the mic at the speaker at around a 50° angle and back it off the cone a foot or so to give the lower frequencies more time to develop. A common micing technique I've heard of is an e609 on the grill right at the dust cap, a 57 at the wall of the cone a foot back, and a ldc maybe 3 feet back for some added depth. Of course, some people fancy a mic in the back of an open cab too. Bottom line is, it's all trial and error and there are no rules for micing, only guidelines. You might try starting the recorder, play something, change the mic angle, play it again, change and so on. Maybe do a few rounds pulling the mic back a few inches each time. Then go back and listen and if it's still not happening, you can either just compensate with eq or look for a mic you like better. The 835 is a great mic though.
First off, you can never go too far... and second, if I'm gonna get busted, it's not gonna be by THAT guy. |
Backing the mic off helped a lot.
As for pickups, that wasn't an option for the guitar I was recording with. I needed something with a trem, and that job falls to a single HB superstrat thing... Next one I build will have a neck pickup, maybe. |
It's the amp and/or the speakers. If it's the only amp you have then pull up your eq, boost in a sorta narrow Q up 15db plus and sweep the frequency until you emphasise the nasty frequencies, then change the boost to cut 8dbs plus and see if that helps. Only potential issue is that you may also kill some bite (which you may need in a dense mix) if you are working in the 1-3khz range.
I'm thinking its the input to the computer.
Are you using any kind of interface or just plugging into the back of the tower?
Martin ___________________________ E. Christina Herr & Wild Frontier Americana Motel |
There's the crux of the dilemma.
Truth is stranger than fact ... It pays to appease all the gods — Gnossos Pappadopoulis YouTube channel • Originals |
#10 (permalink) | |
