Old September 29th, 2009, 12:35 PM   #1 (permalink)
photoweborama's Avatar
M-Audio FastTrack Recording Tips?
I just got a Fasttrack unit in trade, and so far, I'm not impressed.
Any tips on getting the most out of this thing would be appreciated.
Thanks!!
Mark
Best guitar photos on the net!
photoweborama.com!
photoweborama is offline   Reply With Quote
Old September 29th, 2009, 12:58 PM   #2 (permalink)
ibobunot's Avatar
It's USB-1 so two tracks at a time max and possible latency issues. I've never heard anyone say anything good about that unit.
ibobunot is offline   Reply With Quote
Old September 29th, 2009, 01:20 PM   #3 (permalink)
Really? USB 1!! Wow.... I'm glad I did not spend much on the pedal I traded for it...
I'm working on a new album, and I think it will get the job done, but.....
photoweborama.com!
Old September 29th, 2009, 05:42 PM   #4 (permalink)
FirstBassman's Avatar
I have. (I'll spare you the links. )
It's about the least expensive USB input there is and does that job well enough.
Saying "I'm not impressed" really doesn't tell us very much.
I will say this (but I have no idea if this is a result of the Fast Track, my software, or the PC, etc.). I did notice that plugging the guitar (especially the RIC 12-string) directly into the M-Audio did not give very much volume or presence.
Mic'ing an amp gives much better results.
FirstBassman is offline   Reply With Quote
Old September 29th, 2009, 05:57 PM   #5 (permalink)
ibobunot's Avatar
I don't have any personal experience with it I read some bad reviews and bought the Line 6 TonePort UX1 instead....
Old September 29th, 2009, 06:02 PM   #6 (permalink)
This is why I'm not impressed with it.
Direct guitar input is low. I can't stand how the XLR goes to the left channel and the guitar/line input goes the right channel.
What is even worse is that when you press the mono button, you hear mono in both ears, but it still records the right channel only. I would assume then when you press the mono button, it not only bridged the headphone output, but the recording output too, and the same with the mic input. But it still records the right or left channel.
And I also don't like that the guitar input is also the line input, but still only the right channel. So there are no stereo line inputs at all.
Behringer makes a little $35.00 input device I could run my mixer into and I would have all the bases covered that way.
I have someone in Vegas interested in trading my Dynacomp for a Lexicon unit.
That one may work better.
Oh, and I can't plug in the power supply to my laptop because it causes too much noise through the FastTrack.
If I have to, It will get the job done, but it won't as smooth.
BTW YMMV
photoweborama.com!
Old September 29th, 2009, 06:59 PM   #7 (permalink)
StuH's Avatar
BTW YMMV
Your recording problem sounds to me like it is caused from the track input setting that you have chosen within the software, not because of the interface.
What prgram are you recording with?
My music page
http://www.soundclick.com/thrucoloredglass
StuH is offline   Reply With Quote
Old September 29th, 2009, 09:53 PM   #8 (permalink)
I'm not saying I don't know how to get around the problems, I'm just saying that the unit does not work the way it logically should... but then that's my logic.
I'm using Audacity right now and in single track recording mode, it automatically chooses the left channel instead of the right that the unit puts out. I can of course record in stereo, split the track and then delete the empty one, but that just seems a bit cheezy.
All I'm saying is that if you press the mono button, it should output mono. It really should have in and out stereo, but if you can't do than then at least make the mono button output mono.
But that's just me...
photoweborama.com!
Old September 29th, 2009, 10:22 PM   #9 (permalink)
PaisleyIsGod's Avatar
I think these things are actually pretty decent. I use it with Guitar Rig 3 and after some tinkering it's pretty possible to get a good sound. Very simple to use, the price could be better but I can't complain. I've also never experienced the problem you mentioned with mono and stereo, could be something else.
PaisleyIsGod is offline   Reply With Quote
Old September 29th, 2009, 10:55 PM   #10 (permalink)
JosephB's Avatar
i recorded an entire album with it and one condenser mic (drums dont sound that great, obviously) but thats because of the one mic! i love mine...i use it in conjunction with garageband, gave my demo to a well known producer and he was amazed!
http://www.myspace.com/firesidefriendmusic
all of those were recorded with the fast track.
Great things are not accomplished by those who yield to trends and fads and popular opinion. -Jack Kerouac
JosephB is offline   Reply With Quote
Old October 1st, 2009, 04:38 PM   #11 (permalink)
Gee
Gee's Avatar
I have just bought a Fast Track and I have it working OK on my old Mac iBook with Garageband. However, on my PC using Amplitube or NI Guitar Rig and Guitar Combos there is a very annoying thing about the way it works. I suspect it may be a Windows thing.
The problem (PC) I have is that the only way that I have found to use the Fast Track as a guitar input, the Fast Track must be set as the output device, I don't want to use the Fast Track as an output because I have a a perfectly good PCI sound card (M-Audio revolution) hooked up to my speakers. It seems that Windows will not allow you to select one input system and another system for output. Once the output sound card/USB device is selected, that will be used for the only input method. Anyone know a way around this?
PS I also find the guitar input to be very low and the use of one channel is inconvenient.
Gee is offline   Reply With Quote
Old October 1st, 2009, 09:05 PM   #12 (permalink)
StuH's Avatar
Use wdm or mme drivers instead of asio drivers if you want to work with more than one audio device.
It's the asio audio driver that causes that limitation.
My music page
Old October 2nd, 2009, 01:51 PM   #13 (permalink)
Gee
Gee's Avatar
Thanks for confirming this. I've just done a bit of searching about and it appears that Windows does not support this but OS X does. Also found a lot of reports from people who were expecting to plug their guitar into a USB audio interface and then hear it back through their PC speakers and were very disappointed to find that this is not possible. Having to unlug (roll around on the floor under the desk) and unplug the PC speakers and connect to the USB interface is a major embuggeration.
Old October 27th, 2009, 07:05 PM   #14 (permalink)
Yes, unless you buy a pair of monitoring speaker to hook-up on the M-audio interface. This is one of the main reason I switch to mac. GB does it very well.
Fogboundturtle is offline   Reply With Quote
Simple acoustic recording - Rode NT1A + m-audio interface??? wcap Recording In Progress 8 September 7th, 2009 02:54 PM
Audio recording freeware for XP Ed P Recording In Progress 6 August 14th, 2009 10:31 PM
Using M-audio Fasttrack pro as d.i. box iris186 Recording In Progress 0 March 15th, 2009 12:42 PM
Great SOS Guitar Amp Recording Article with audio demos CIM Recording In Progress 2 September 1st, 2007 11:55 AM
recording this weekend. any tips? (long-ish) captain gorgeous Bad Dog Cafe 13 December 19th, 2005 11:46 AM
