Old August 20th, 2009, 09:02 AM   #1 (permalink)
bignote's Avatar
Hints on Recording Gear
O.K. after years of gigging in bars and live houses, the scene is starting to dry up a bit. I am wanting to get started in recording my own clips, or put my ideas over backing tracks. I have a Mac with Garageband and a couple of good guitars. What can you all recommend for the gear in between the two. I am thinking Line 6 or is there another beast out there. I have a small apartment so mic'ing an amp is out. Any suggestions to start me out? Thanks, I really appreciate it.
bignote is offline   Reply With Quote
Old August 20th, 2009, 10:34 AM   #2 (permalink)
Andy Summers's Avatar
Ive got a Line 6 toneport and it is amazing...I have the UX1 that has been discontinued, so you could find it for around 70 bucks right now...best deal out there..The sound is phenomenal!
Andy Summers is offline   Reply With Quote
Old August 20th, 2009, 09:39 PM   #3 (permalink)
slowpinky's Avatar
Has the UX1 been replaced by the toneport GX? It looks to be a very similar machine.
"We were making music before language"
slowpinky is offline   Reply With Quote
Old August 20th, 2009, 11:30 PM   #4 (permalink)
bloos66's Avatar
The Toneport UX1/UX2 have been replaced with the Pod Studio UX1/UX2. I don't think there's a lot of technical difference between the old and new models.
I use a Toneport UX2 with both Mac and PCs with great success. The PodFarm software is excellent and gives you lots of amp/cab/pedal simulations. Great to use with headphones as well.
The only problem with them is that you need to have them plugged into a computer to use them. If that's an issue, then the POD range might be better. You can still connect them to a computer for recording but at least you don't need a computer to run them.
bloos66 is offline   Reply With Quote
Old August 21st, 2009, 12:11 AM   #5 (permalink)
rangercaster's Avatar
the Crate Profiler 5 is similar to a Roland MicroCube or Vox DA5, plus it is compatible with Traktion software (included) and it has a built in USB port ... they should still be available ...
"Work is the curse of the drinking classes."
Oscar Wilde
Anyone Building Recording Gear? micpoc Burnt Fingers DIY Effects 12 July 16th, 2009 01:44 PM
Need home recording gear... what to buy... hooboo Recording In Progress 7 June 26th, 2009 08:53 PM
Question about home recording gear TraditionalCountry Bad Dog Cafe 6 July 11th, 2006 12:04 PM
Help - hints on how to set a delay? telewacked The Stomp Box 2 April 28th, 2004 03:33 PM
What recording gear are you using? hippietim Telecaster Discussion Forum 20 April 27th, 2003 08:23 PM
