Old June 26th, 2009, 02:23 PM   #1 (permalink)
HappyTelecaster's Avatar
Preamp Nominal Level
Hi @ All!
I have an old Marshall 9000 tube preamp that I want to use for recording vocals and guitars on my PC. I want to connect the two Master Outputs of the preamp with the Line-In socket of the Soundcard. The preamp has a switch at the back offering three settings for the so-called "Nominal Level":
+4dB , -10dB and -20dB. Which setting is the right one for this type of Harddisk-Recording? I would appreciate it much if you could help me because I don`t want to blow up the Soundcard.
Greetings,
HappyTelecaster
Seek nature .
HappyTelecaster is offline   Reply With Quote
Old June 28th, 2009, 02:24 PM   #2 (permalink)
woodman's Avatar
i would start with -10dB and see how that works. i don't think you'll be in danger of blowing up your soundcard.
Old June 28th, 2009, 04:49 PM   #3 (permalink)
mudbean's Avatar
What kind of soundcard? Most pro-sumer grade uints run at -10dB. +4dB is where the real pro stuff runs - very hot. Never heard of -20dB as a preamp out level - I guess you could consider that a padded output.
mud
MudBean Music
Nekkid Bart: "This is the worst day of my life."
Laffing Homer: "Worst day SO FAR!!"
mudbean is offline   Reply With Quote
Old June 29th, 2009, 04:43 AM   #4 (permalink)
It`s not even a pro-sumer card. It`s just what came along with the PC, some Terratec 5.1 Surroundthing - very cheapo but for rough sketches of my work that`ll do. Thanks for your tips guys .
Seek nature .
Going to the next level PraiseCaster Worship Service Players 8 March 2nd, 2009 12:28 AM
At what 'level' is everyone at? Lerb21 Tab, Tips, Theory and Technique 44 July 30th, 2008 11:18 AM
Where do you set your OD level? cacibi The Stomp Box 16 March 11th, 2006 02:09 PM
Own fret level? lewis Tele-Tech 28 February 28th, 2006 12:06 PM
Nominal Output Voltage of Tele Pickups tdowns Tele-Tech 0 December 20th, 2005 10:00 PM
