Old June 9th, 2009, 12:15 PM   #1 (permalink)
Recording clean electric guitar - amp sim?
I'm trying to find a simple way of going straight into my recording setup to record clean electric guitar - that doesn't sound horribly 'D.I'd'. I have a POD 2.0, a Zoom pedal with amp emulations, a Award-Session DI box, and I have Native Instruments software and the 'Pro Amp' Emulations that come with Logic. Most are fine for overdriven sounds, many sound 'nasal', boxy, or thin - often like the amps they're emulating. I just want to plug my guitar in and have the full sound, clean. I can nearly get there by EQ'ing. Anyone tried the little FX boxes that look like Fender Bassman and Deluxe (Are they Boss/Fender?). I guess I like the basic clean Fender sound... Thanks.
tonyguitargoat is offline   Reply With Quote
Old June 9th, 2009, 12:20 PM   #2 (permalink)
Daddydex's Avatar
Take a look at the Amplitube Fender demo. I have had the same concerns in the past but I think Amplitube Fender gets pretty close.
Dan
My Music Page
Daddydex is offline   Reply With Quote
Old June 9th, 2009, 12:21 PM   #3 (permalink)
Daddydex's Avatar
http://www.ikmultimedia.com/fender/download/
Dan
My Music Page
Old June 9th, 2009, 01:44 PM   #4 (permalink)
woodman's Avatar
i'm with Dan ... if i could afford it, i'd jump on the Amplitube in a heartbeat. i've got a POD 2.0 also, and with laborious tweaking, i can get some pretty fair Fender sounds. when i get a good one, i save it, rather than going thru all that again. dialing back the Drive works well for me, but then i have to give it a kick in the pants from my tube preamp because the gain drops drastically when you reduce the Drive.
Old June 9th, 2009, 02:21 PM   #5 (permalink)
Astro1176's Avatar
+1, to my ears Amplitube is leading the way with believable clean sounds.
Astro1176 is offline   Reply With Quote
Old June 11th, 2009, 06:59 PM   #6 (permalink)
You can get AmpliTube Fender Studio for $99, and that comes with a decent recording interface. More importantly, it comes with the Twin, Supersonic and Vibratone......
Professorbx is offline   Reply With Quote
Old June 11th, 2009, 10:09 PM   #7 (permalink)
Ben Harmless's Avatar
Hmmm. I've played with Amplitube as well, and it's cool and all, but I really feel like you've got the gear to get a quality tone already. The POD or the Award-Sessions box should have some great sounds in them for clean. Do they all sound crappy otherwise? Sometimes issues with preamps and gain staging can really compromise a track.
If you've got any option to try them out elsewhere, I'd give it a shot and see if maybe there's not something else going on in the recording chain.
...Or they really aren't what you're looking for. I dunno. Maybe Amplitube?
- B. Simpson
"...Because we all expect the truth, we must be the best of fools."
- Stiff Little Fingers
Old June 12th, 2009, 09:07 AM   #8 (permalink)
If your Zoom pedal has an Acoustic simulator - like the on the G2.1u - try using that setting instead of any of the electric guitar amp/cab settings. Not promising but I've found that gives a good clean sound for recording electrics.
pengipete is offline   Reply With Quote
Old June 15th, 2009, 05:37 AM   #9 (permalink)
Thanks, guys. I keep trying all these options for both clean and overdriven sounds, and they're good. I did a comparison recently using the 'front ends' of a couple of real amps (Crate and Session) and thought they were OK. I even tried miking the amps as a comparison. Sounded good. But like all of us I just want better! Unfortunately, I'm comparing my Tele tone with that of Brent Mason and Brad Paisley!!!
Old June 15th, 2009, 12:13 PM   #10 (permalink)
Here's another thought:
Never listen to your guitar tracks solo'd.
Okay, that's a bit global, but keep the mindset of each track contributing to the mix. I've heard some truly horrible tones that did exactly what they were supposed to do in the mix. You may find that the stuff you're hearing that you don't like is not what makes the tone once it's in the mix.
- B. Simpson
Old June 15th, 2009, 12:24 PM   #11 (permalink)
kman900's Avatar
Used to record with real amps, hardware simulations (POD) and Ampfarm, as a soft-solution . . worked fine each time.
Using an apostrophe for plural sucks
kman900 is offline   Reply With Quote
Old June 15th, 2009, 01:05 PM   #12 (permalink)
Parma_TeleMon's Avatar
I took the Blackface model on my ToneLab LE and went "Magic 6" on it. Way sweet and authentic.
Packin' a Tele, lookin' fer trouble....
Parma_TeleMon is offline   Reply With Quote
Old June 18th, 2009, 09:13 AM   #13 (permalink)
play_loud's Avatar
+ 1 to Fender Amplitube.. Just got it, i'm in love!
play_loud is offline   Reply With Quote
Old June 21st, 2009, 07:23 PM   #14 (permalink)
Just downloaded the Amplitude demo, the Fender deluxe sounds sweet using a jd10 on the front end.
Vikki
vikki is offline   Reply With Quote
Old June 21st, 2009, 11:24 PM   #15 (permalink)
Vikki
Which version? The Fender emulations in AmpliTube 2 sound good, but the ones in Amplitube Fender are mind blowing. The funny thing is that I am also a huge Vox fan, and the ProJR really sounds "Vox-y" to me. So underrated....
Old June 22nd, 2009, 08:21 AM   #16 (permalink)
I downloaded the Amplitude Fender, its pretty expensive here in the uk though i was a bit shocked by the price.
Vikki
Old June 22nd, 2009, 11:15 AM   #17 (permalink)
Vikki
I'm always getting coupons from them in the mail, they are pretty good about that. Sign up for their mailing list, they have a ton of promos.
Old July 9th, 2009, 06:02 PM   #18 (permalink)
JimmyJam's Avatar
+1. This thing is awesome. The sound is actually unbelievable.
Out of all the amp modeling I've come across, this one has been the most convincing of all of them.
JimmyJam is offline   Reply With Quote
Old July 9th, 2009, 07:11 PM   #19 (permalink)
StuH's Avatar
You guys are bad influences.....
Here I am trying to cut down on purchases, trying to pay the freaking bills off and now you got my software gas meter past 10 on this Amplitube Fender thing.
Can any of you guys that used other software (ie: Guitar Rig, Pod Farm, Revalver ect...) that are smitten with Amplitube Fender tell me this.
Have you run through a tube pre when using the software I mentioned instead of going through pure digital DI, and is Amplitube Fender still miles ahead of the tube pre technique?
If yes and yes, I might have to get it.
My music page
http://www.soundclick.com/thrucoloredglass
StuH is offline   Reply With Quote
Old July 13th, 2009, 02:54 PM   #20 (permalink)
JimmyJam's Avatar
StuH,
I have used a Line 6 Flextone II amp for a few years, a Roland VS880 with some guitar modeling, and Guitar Rig.
I have not used a tube preamp when using modeling software.
I'm running an M-powered fast track pro into the PC via USB.
Amplitube Fender sounds really good to my ears.
There is something about the dynamics and response of Amplitube Fender that just sounds/feels right. It's not perfect, but it's definitely better than most of what I've used before. I like the pro-junior in there the most.
Get the demo. Test it out for yourself. Hope this helps.
Old July 13th, 2009, 06:06 PM   #21 (permalink)
Daddydex's Avatar
StuH, they have a 10 day fully working demo on the product page. Give it a go!
Dan
My Music Page
Old July 13th, 2009, 10:49 PM   #22 (permalink)
StuH's Avatar
I will do that. Good point about the demo.
Good to see ya around Dan. Haven't seen you post for awhile.
Hope all is well with you and your family and a long over due congrats on the newest member of your family.
Thanks folks
My music page
Old July 14th, 2009, 12:35 AM   #23 (permalink)
Daddydex's Avatar
Thanks StuH! The little guy is 8 months old now and is suddenly mobile. I am having a ball but I really should have done this 20 years ago.
After reading your post it occurred to me that I haven't committed anything to tape since July or August of 2008. One year. Que Sera Sera.
I hope you and your wife are enjoying your summer. I will swing by your soundclick page and give a listen. I am sure you have some new stuff up since I last checked in.
Dan
My Music Page
Old July 14th, 2009, 02:25 PM   #24 (permalink)
Dan
They also just posted an update to Amplitube Fender-they put in a rack reverb, a trem pedal and some other new effects. So I guess now is a good time to check it out!
Old July 15th, 2009, 03:53 PM   #25 (permalink)
Here's a WAY low-cost solution. At least a partial solution.
Get a Vox Amplug headphone amp. There's a classic AC30 version, vintage version, metal version, etc. Choose the one you like. Plug guitar into Amplug input, plug Amplug output into your recording interface. You get an excellent Vox amp sound, volume gain and tone control. EXCELLENT for recording a basic clean or overdriven guitar sound.
It's not infinitely flexible, each Amplug is modeled on only one particular Vox AC30 style or sound, but it's an amazing way to get a guaranteed beautiful Vox amp sound -- clean or with as much gain/distortion as you like -- into your recorder.
For wide variety of amp models/basic sounds, buy several of the Amplug models. There's even a model for bass guitar.
http://www.voxamps.com/amplug/
fendorst is offline   Reply With Quote
Old July 15th, 2009, 03:59 PM   #26 (permalink)
I just re-read the Vox Amplug web page. Some of the Amplugs are modeled on US amps, high-gain amps, etc. So you have more choice than just buying Vox amp sounds.
I've got the classic AC30 and it nails that sound. Search for sound clips and see if that or one of the other models is what you're looking for.
In any event, it's an excellent low-cost solution to recording a guaranteed beautiful tone first time/every time you lay down a guitar part.
Old July 15th, 2009, 06:41 PM   #27 (permalink)
lasthippy's Avatar
Probably a very stupid question...but do these work with the recessed jack plug on a Fender (as opposed to Squier etc) tele? I'd read somewhere that the design of the amplug and the jack socket meant that they didn't fit together well?
Three chords? Can't I just move 'E' around the neck?
Having some fun. I’m the tele player (natch) http://www.flickr.com/photos/lasthip...7614625083654/
lasthippy is offline   Reply With Quote
Pick just one tone: acoustic, clean electric, or dirty electric? cwcowell Bad Dog Cafe 19 April 13th, 2009 12:09 AM
Guitar Clean Up Day... 91xlntS-3 Telecaster Discussion Forum 6 April 8th, 2009 10:30 AM
Recording sessions : how to get a juicy clean tone ? nic'o'caster Recording In Progress 37 March 13th, 2009 08:28 PM
Recording acoustic-electric guitars Valvey Recording In Progress 6 August 28th, 2007 04:43 AM
Recording a big,clean guitar sound greggorypeccary Recording In Progress 10 March 4th, 2007 04:35 PM
