ProTools: ghosts! what th' ... ?
i'm getting bleedthrough on PT tracks that's got me baffled ...
backstory: i obtained the raw tracks and PT 5 rig that spawned the last Stragglers album. two key guys have left the band since, and i'm laying down new tracks over the existing ones to reflect our current lineup. one song requires singing in another key (transposed from F to A). i thought i could use the drum tracks and start from the bottom up retracking the other instruments. but i'm getting lead vocal and steel bleedthrough. (ironically, those are the two guys who've left the band.) at first i thought maybe the studio was leaking sound when we put down the bed tracks, but then i remembered the lead vocal was tracked weeks after the drum tracks went down. hmmm ... so where the hell is it coming from? i haven't noticed it in the other three album songs i've worked up for redub, but since they're still in the same keys, it's hasn't been intrusive. ... the buses check out clean, but a few channels (chiefly the overheads and hi-hat) are picking it up. my objective is do produce a decent current demo on the cheap by using the existing tracks and plugging in the new personnel. but i'm wondering if i oughta gamble on this drum track ... the bleed isn't dominant, just enough to be annoying when soloed. anyone else worked through a problem like this?
Moderator
Anyone? Hey, EVERYONE! Unless you have complete isolation or do one track at a time... you end up with some bleed.
If it is just a demo, I'd leave it. If it is fo' real, I'd see if I could get the guy to recut the track.
We don't see things as they are, we see them as we are |
I have never had pro tools tracks 'bleed' - but if the session is compicated, there may be prefade busses feeding reverbs, and solo-defeated reverbs.
Step 1: show all tracks - make sure there are no hidden tracks which are playing. Step 2: deactivate all the unused tracks especially vocals and so on - leaving only the drum tracks. Not just mute them - make them grey'd out. Step 3 (for sanity and absolute certainty) deactivate or remove all the sends and plugins so you can hear the audio in its rawest state. Now is there still bleed? If so, since the drums were recorded at a different time to the vocals - maybe the audio you have is some comp or bounce of the drums where bleed may have occured, or might include a comp or bounced reverb which had a vocal sent to it. Listen to each track - is spill on all the tracks? If you can still hear spill, for a sanity check I would be tempted to import the audio into another wav editor or DAW (just the drum tracks, or one drum track at a time) and see if you can hear the bleed there too. |
#4 (permalink) | ||
that's my inclination, although completing this tune would be heavy lifting ... see if it gets buried in the mix enough to satisfy promoters and clubowners. Quote:
#5 (permalink) | |
Moderator
I just re read it again.. hmmm, the only time I've seen that happen is when someone left the monitors on in an open room or when someone's headphones were up super loud.
#6 (permalink) | |||
the worst offenders are the overhead pair, plus a little in the hi-hat and the faintest bit in the toms pair. the snare and kick are clean. the best i could do was to bounce to AIFF, burn a CD and dump it into Garageband on my Intel Mac ... i couldn't hear as much of the leakage, but it was still there. my hope is that it'll be buried when i get the other parts on.
Hmmm it does sound as if the bleed occured during a bounce (possibly vocals were sharing the drum reverb) - or the other possibility is maybe there was some guide vocals or the drummer was singing along as he played?
It is always hard to predict what will get lost in a mix and what will cut through, you might never know it was there or it might even add an ethereal harmony! |
oddball solution: went back into the original session file, isolated the drums again and inverted the phase on one of the overheads ... instant frequency cancellation! the cymbals don't seem to be affected, but the vocal/steel bleeds were reduced from a muted cry to a faint whisper. i think the track will work fine now.
#9 (permalink) | |
This will mess with mono-compatibility but that shouldn't bother you unless you have a huge market in AM radio. Be careful of phase issues in the mix. Jim
"A jazz musician is a juggler who uses harmonies instead of oranges." Benny Green |
#10 (permalink) | |
it was the only solution i could think of at the time. but after careful examination, it didn't make enough difference to be worthwhile, since it changed the overall sound of the drums. so i reverted to the original track, leakage and all. as i've begun to lay down the other tracks, i don't think it's gonna come through enough to notice.
