Old July 8th, 2008, 11:33 PM   #1 (permalink)
ghosttour's Avatar
TASCAM DP01FX misery
I have been using the following setup for about a year:
AKG CS1000 --> PreSonus Bluetube --> TASCAM DP01FX
I was getting decent sounds until a month or so ago and then everything went south. I've been as scientific as I can about figuring it out, but I'm honestly not doing anything different than before and I have inspected every link of the chain to see if something is wrong. Everything seems to be in working order - the only difference is the quality of the recordings. Everything sounds like it's clipping, kind of. I tried setting the gain lower than previously and it's still fizzy and thin-sounding. It's absolutely maddening - particularly since I'd much rather concentrate on songs than knob twiddling. Even though I'm not particularly good at writing songs, I'm much worse at knob twiddling.
Here are my suspicions of what could be wrong:
1) Need a new tube for the Presonus - this seems unlikely since I don't record THAT much - but stranger things have happened, I guess.
2) XLR cords are cheap and have "gone bad"?
3) Damaged mic somehow? I have two of the same mic and both yield the same results so this seems unlikely.
Any comments or suggestions are welcome. I can of course provide more info as needed. Thanks y'all.
www.myspace.com/brasssaddles
ghosttour is offline   Reply With Quote
Old July 11th, 2008, 12:06 PM   #2 (permalink)
ghosttour's Avatar
bump.
Old July 11th, 2008, 12:14 PM   #3 (permalink)
jussishow's Avatar
Couple of questions :
Have You tried recording with a different preamp ?
Have You tried recording directly into the TASCAM ?
B-bender, HW1 Texas & CS Thinline relic ... :-) + a bunch of other stringed instruments ... Pictures (family album...) in gallery
jussishow is offline   Reply With Quote
Old July 11th, 2008, 01:06 PM   #4 (permalink)
ghosttour's Avatar
Unfortunately, the BlueTube is the only preamp I have.
I was doing that before I got the preamp; the signal was always very low. I hadn't thought about taking it out the chain completely to see if it's the problem - I'll try this tonight and see what happens.
Old July 11th, 2008, 01:21 PM   #5 (permalink)
markophonic's Avatar
Sounds like a preamp problem to me.
Try using the built in preamps and see if you get the clipping. Push them hard if you are getting low levels.
I had a similar problem once using a cheap ART preamp that worked beautifully for awhile then just went south.
http://www.brianvanderark.com/
markophonic is offline   Reply With Quote
Old July 11th, 2008, 10:59 PM   #6 (permalink)
ghosttour's Avatar
I think markophonic is the winner - skipping the preamp seems to solve the problem. I don't think the DP01FX has a built-in preamp; I'll have to check the manual. It has effects, amp models and vocal "preamps" that are really more like vocal effects - big echoey rooms, "bullhorn" sounds, etc. However, the sound straight to the unit is sterile and boring - one of the reasons I got the BlueTube.
I guess I'm in the market for a new preamp.
