Latency Problem
I got a Behringer UCA202 USB interface for my laptop.
The ASIO driver you can download from their site does not work on my computer. So I downloaded a driver from asio4all. Its a free download, it works, but there is still too much latency. Any suggestions for another driver or some other solution? |
| Sponsored Links |
Make sure the device drivers for both your Behringer interface and your USB ports are the most current. See if the UCA202 driver control panel has a setting for buffer size and make it as low as it can go without cracling or breaking up. You can also use the direct monitor button to send the in directly to the headphone out so you can listen to the dry signal with no latency.
"...You don't need faith if you know it's gonna work!" "The views expressed here are mine and do not reflect the official opinion of my employer or the organization through which the Internet was accessed." |
I get the latency problem as I listen to previously recorded tracks and add a new track.
I read somewhere that good recording software should have automatic latency correction but I don't know. I'm going to try a couple more programs. Outside of that, I'm doubting you can really do even a 4 track recording on a notebook computer through USB ports. Too slow. |
#4 (permalink) | |
OK guys I answered my own questions.
Turns out GOOD SOFTWARE makes all the difference. I am now making multi-track recordings with no latency on a rather average laptop. I tried a free download someone suggested called Multitrack Studio and that worked good. Then I tried an older, but very good program I have not used for years - Cool Edit, and that works. Audacity did not work well at all. Thanks for the suggestions. |
Some of those older programs that did not have automatic latency compensation still offered a way to make a manual adjustment in their audio options. In other words, hey buddy I can't calculate the latency for you but if you tell me how many samples to adjust by I will do it for you.
Even some of the well known name packages (earlier ersions within the last three years) didn't offer automatic delay compensation. Name of product withheld. You are absolutely correct though, the software you are using does make a huge difference, even in percieved quality of audio. |
